| | Peerless 1200 info? | |
TedTheDestroyer Member
![TedTheDestroyer](https://2img.net/u/2812/37/66/46/avatars/2422-6.jpg)
Age : 25 Join date : 2015-11-07 Points : 3338 Posts : 89 Location : Wisconsin
![Peerless 1200 info? Empty](https://2img.net/i/empty.gif) | Subject: Peerless 1200 info? May 12th 2017, 11:44 am | |
| Does anybody have information on the peerless 1200 or on how to lock it? 3 speeds forwards 1 reverse. Cast iron case. | |
| ![Go down](https://2img.net/i/empty.gif) | | RichieRichOverdrive Moderator
![RichieRichOverdrive](https://2img.net/u/2812/37/66/46/avatars/2731-86.jpg)
Age : 22 Join date : 2016-10-29 Points : 7020 Posts : 3898 Location : Lewisburg, KY
![Peerless 1200 info? Empty](https://2img.net/i/empty.gif) | Subject: Re: Peerless 1200 info? May 12th 2017, 6:23 pm | |
| Was one of peerless' first transaxles, in early John Deeres. From what I can tell from the peerless manual, they have a differential like an 820, with carrier and spiders. Can do something like Doc's 820 lock or a fozzy locker where you fill in the gaps of the axle gears with a welder. From what I've heard they are as tough as a 633 or tougher because of the cast iron case. | |
| ![Go down](https://2img.net/i/empty.gif) | | AllisKidD21 Moderator
![Peerless 1200 info? Empty](https://2img.net/i/empty.gif) | Subject: Re: Peerless 1200 info? May 12th 2017, 6:30 pm | |
| I think Doc locked the transaxle in his old John Deere garden tractor using strategically placed pieces of sheet metal. Pretty sure it was a 2300 series, but the differential assembly could be the same. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100
| ![Go down](https://2img.net/i/empty.gif) | | TedTheDestroyer Member
![Peerless 1200 info? Empty](https://2img.net/i/empty.gif) | Subject: Re: Peerless 1200 info? May 18th 2017, 12:13 pm | |
| If I already have a problem with shattering woodruff keys, will this make it worse? | |
![Peerless 1200 info? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Peerless 1200 info? | |
| Who is online? | In total there are 116 users online :: 0 Registered, 0 Hidden and 116 Guests
