| craftsman with a swing arm | |
Fattypipemuarry Member
Age : 29 Join date : 2011-06-02 Points : 5034 Posts : 62 Location : Russell County Kentucky
| Subject: craftsman with a swing arm June 12th 2011, 12:47 am | |
| hey guys i busted the rear end in my crafts man so im puttin a ragb eith 3 gears an reverse on it hooked into a 87 honda 250x swing arm an running disk breaks any hints or coments holler i will get pictures up soon | |
Jordan Member
Age : 30 Join date : 2010-10-03 Points : 5352 Posts : 170 Location : Ontario Canada
| Subject: Re: craftsman with a swing arm June 12th 2011, 8:59 pm | |
| please post lots of pics, i want to do the same thing with a 3 speed i have and an '86 trx200sx axle | |
| Subject: Re: craftsman with a swing arm June 12th 2011, 10:04 pm | |
| i have bout got every thing mocked up an ready to bolt in havin promblems with my front any suggestions | |
| Subject: Re: craftsman with a swing arm June 21st 2011, 12:34 pm | |
| hey guys i have uploaded a video of my mower would yall care to chech it out an comment i will put it on here asap after it down loads | |
Guest Guest
| Subject: I am going the other way. mower engine on a polaris trail boss June 21st 2011, 12:47 pm | |
| I picked up a '94 trailboss last week for a parts bike . no motor or tranny, most electric parts are gone, no tank or throttle. Good tires and plastics. Started hacking up the frame and put in a 17.5 hp briggs single and a peerless 797. Need to finish the mounts and waiting on $60 woth of chineses quad parts. The chineese quad parts are dirt cheap and will replace a lot of honda parts. (not sure about the quality yet) might check them out if you are needing sprockets or throttle stuff. |
| Subject: Re: craftsman with a swing arm June 21st 2011, 3:42 pm | |
| - rat88 wrote:
- I picked up a '94 trailboss last week for a parts bike . no motor or tranny, most electric parts are gone, no tank or throttle.
Good tires and plastics. Started hacking up the frame and put in a 17.5 hp briggs single and a peerless 797. Need to finish the mounts and waiting on $60 woth of chineses quad parts. The chineese quad parts are dirt cheap and will replace a lot of honda parts. (not sure about the quality yet) might check them out if you are needing sprockets or throttle stuff. im goin try my best to leave my stock throttle unless it pisses me off i got a video up on youtube yall check it out bad ass beast | |
Duranate New Member
Age : 51 Join date : 2011-06-06 Points : 4932 Posts : 15 Location : Elk River, Mn
| Subject: Re: craftsman with a swing arm June 26th 2011, 5:46 pm | |
| you chew spittin redneck! lol. I love it man thats a pretty good start on that deal. any give on that suspension would be sweet and help out on bumps. i think the most force would be on the top of the chain when the motor is pulling so i think it should try to remain as straight as possible, then take up slack on the bottom side of the chain. keep us posted as you get things done. I'd love to come up with some kind of rear " suspension" for my project. | |
| Subject: Re: craftsman with a swing arm June 26th 2011, 11:49 pm | |
| - Duranate wrote:
- you chew spittin redneck! lol. I love it man
I'd love to come up with some kind of rear " suspension" for my project. that was good ole grizzly an i took it for some what of a test drive my belt sliped so much but i wann run a 6 inch in front with a 2 in back or a 4 cause my gearbox is lowed gear so i want speed an torque as well | |
Duranate New Member
| Subject: Re: craftsman with a swing arm June 27th 2011, 12:48 am | |
I'd love to come up with some kind of rear " suspension" for my project. that was good ole grizzly an i took it for some what of a test drive my belt sliped so much but i wann run a 6 inch in front with a 2 in back or a 4 cause my gearbox is lowed gear so i want speed an torque as well i love grizz too. yea, i hear yea on that speed. would it be easier to put a bigger wheel on the gearbox? i dunno, just mite be easier, i dunno. that would take up some slack in the chain too. you have a good start, can you put an extra pully in someplace to take up extra belt length? | |
| Subject: Re: craftsman with a swing arm June 27th 2011, 11:13 am | |
so damn dumbass welded that gear on an my chain is tight now | |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
| Subject: Re: craftsman with a swing arm June 27th 2011, 12:28 pm | |
| how much speed are you looking for? depending on your back sprocket and how big your tires are, with 20 inch tires a 5 on the motor and a 5 on the gearbox can get you 20 if you sprockets arent that big. also your not gonna get that torque if your looking to go over 25. also one tip of advise is the gearbox has 6 mounting holes, use them the more suport you have on them the better ive broke the input shafts on them and have busted them in half then its a bitch to find them cause they arent that common | |
| Subject: Re: craftsman with a swing arm June 27th 2011, 9:49 pm | |
| - redzz02 wrote:
- how much speed are you looking for? depending on your back sprocket and how big your tires are, with 20 inch tires a 5 on the motor and a 5 on the gearbox can get you 20 if you sprockets arent that big. also your not gonna get that torque if your looking to go over 25. also one tip of advise is the gearbox has 6 mounting holes, use them the more suport you have on them the better ive broke the input shafts on them and have busted them in half then its a bitch to find them cause they arent that common
i got 22s on the back an its 4 mountin holes have you checked out my video on youtube | |
Guest Guest
| Subject: craftsman with a swing arm June 27th 2011, 10:00 pm | |
| Is the sprocket welded on the tranny? you could always change ratio on the atv axle. it should have a slack adjuster too. Dont want to put too much lateral pull on that gearcase. you will rip the shaft right out of it. the swing arm will tighten up the chain when the spring compresses. I am not real crazy about a 2" on the back. not enough surface area to grab good and the tight radius will break down the belt real quick |
| Subject: Re: craftsman with a swing arm June 29th 2011, 7:55 pm | |
| - rat88 wrote:
- Is the sprocket welded on the tranny? you could always change ratio on the atv axle. it should have a slack adjuster too. Dont want to put too much lateral pull on that gearcase. you will rip the shaft right out of it. the swing arm will tighten up the chain when the spring compresses.
I am not real crazy about a 2" on the back. not enough surface area to grab good and the tight radius will break down the belt real quick yea it is welded up good an it aint got no adjuster but i like a 2 inch just need a really tight belt an some rhino line as for the chain it is just right should all go together good just like a belt on it now an a masterlink | |
