| Chris's **Tracta-Cooler** [2017 Build-Off Entry] [Finalist] | |
+8MightyRaze prancstaman TheBeal tater195 CraftsmanQuad19 Mudgutz_Customs Doc Sprocket Cityslickerbuilds 12 posters |
Cityslickerbuilds Member
Join date : 2016-06-14 Points : 3140 Posts : 51 Location : Ohio
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5713 Posts : 1402 Location : Central PA
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: Chris's **Tracta-Cooler** [2017 Build-Off Entry] [Finalist] September 17th 2017, 9:37 pm | |
| Is that an MTD steering wheel? Hahaha, she looks great man! The shifter cable setup and stuff looks really professional. Love the Coors handle as well haha "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Chris's **Tracta-Cooler** [2017 Build-Off Entry] [Finalist] September 18th 2017, 9:42 pm | |
| - AllisKidD21 wrote:
- Is that an MTD steering wheel? Hahaha, she looks great man! The shifter cable setup and stuff looks really professional. Love the Coors handle as well haha
Lol yes it is an MTD steering wheel. Glad you noticed the shifter handle, I thought it would be a nice touch. | |
| Subject: Re: Chris's **Tracta-Cooler** [2017 Build-Off Entry] [Finalist] September 18th 2017, 9:51 pm | |
| At this point with the build, I could almost submit a final video with all the working parts needed to compete. But of course this build it far from being complete. I doubt I will have the final product done by the time line. How ever I will enter what is done at that point. Here really soon I will start making the body panels. I have an idea of what I am going to do with the rear tins. But at this point I have no clue what I am going to do with the front tins. As you all know this is my first ever build and I have never messed with sheet metal. So I guess next for that is to figure out what material I am going to use and what gauge of sheet metal to get that I can bend somewhat easily with the limited tools I have, and not be so thin it dents to the touch. I am kinda thinking of using 18ga or 20ga. Does anyone have any input on that to help a feller out? | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7778 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: Chris's **Tracta-Cooler** [2017 Build-Off Entry] [Finalist] October 15th 2017, 9:43 pm | |
| Ok guys I am do for a update on the cooler build. I have been trying to get as much time in as possible lately to get closer to being done with her for the contest deadline. As I look at the deadline approaching fast, I have came to the conclusion the build will not be complete by that time. I will however do my best to have it running in eligible condition to enter in the voting portion of the contest. Tonight my welder took a crap on me and looks like I am going to have to pick up a new one. For now I am just going to replace it with another HF CE 90amp flux, how ever later down the road I will invest in a better welder. First up I have redone the chain guide/tensioner's again for the 5th or 6th time. This time I believe I have it correct. As you guys have probably seen it on my FB page being test driven the last one worked. The issue I noticed with the double wheel setup is under load it would pull down on the whole assembly pulling it out of line. So what I was create a cross member to run all the way across on each side of the swing arm. For the double wheel setup, I welded on two bolts to the assembly for the wheels sticking up. They then run up through the cross-member. The reason I did this is so I can adjust the tension on the chain by loosening the bolts or tightening them. Please see pic's for reference. " /> " /> Second up I have started fabricating the hood for the engine. I was at the metal shop and bought a 4x8x1/8 steel sheet of diamond plate that was "scrap" for $50. I had a general idea for the design I wanted for the rear engine cover. So after cutting out some pieces with my angle grinder with probably 100 cut off wheels I had the panels I wanted. I tried trimming them up to be straighter with the new band saw I picked up. and then also with the grinder. Of course my skill level is beginner on all this they are not 100% straight cuts. Once the panels where cut I started mocking them up on the Tracta-Cooler. You will notice on each side of the side panels I cut a triangle out. I've watched Doc Sprockets video on Fugazi having to cut an angle into the hood to get it to hinge the way he wanted. My shock mounts are right in that spot. So I just cut the line from the front corner of my cut out for the shock to the back side. The cover is going to hinge up towards the cooler. So now it should hinge just fine. My plans for the smaller sections will be to screw them onto the frame. The reason I am going to do that is so If I need full access to the engine I can take the whole cover off and those side pieces. " /> After having it mocked up and starting to weld the panels together, this engine cover weighed a ton! I started trying to come up with a way to shed some weight out of it. Keeping in mind that the engine is air cooled I wanted to come up with a way to cut some sections out for air flow and make it look good. I was sitting in my chair looking around for ideas and I noticed this just sitting their looking lonely.The hood off the decommissioned #TPPD tractor! " /> So I started hacking it up for the louvers to get air into the engine cover with a little style. " /> Once I cut it up into the pieces I needed, I cut out spots in the engine cover to size. I grinded down some of the diamond pattern for the pieces to sit flush on panels. " /> Here are some sneak preview pic's of my idea for these. " /> " /> " /> " /> Here are the most recent pictures from tonight after my welder crapped out on me. I'm not finished welding the last panel on to it as you will see in the pictures. But I hope to be able to get a new welder this week to finish this up and call this portion complete. " /> " /> " /> What are your guys thought on the engine cover so far? Good design idea or no? | |
Age : 22 Join date : 2016-10-29 Points : 7210 Posts : 4013 Location : Lewisburg, KY
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5092 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Chris's **Tracta-Cooler** [2017 Build-Off Entry] [Finalist] November 21st 2017, 8:04 pm | |
- She's shaping up really nicely! I wonder what you'll ever get to use that bumper on lol. Maybe some lifted atvs? Lol
Goona be used for pushing hippy's out of the way, ( the protester pusher) LOL. | |
