| | My monster Murray build | |
AlaskanJoe907 New Member
Age : 25 Join date : 2016-09-06 Points : 2939 Posts : 11 Location : Wasilla, Alaska
![My monster Murray build Empty](https://2img.net/i/empty.gif) | Subject: My monster Murray build January 7th 2017, 2:07 am | |
| Well here's what I got so far on building my Monster Murray Build, I plan on doing a radius arm suspension with a panhard bar ![My monster Murray build 15369912](https://i.servimg.com/u/f37/19/56/92/67/15369912.jpg) here it is stock ![My monster Murray build 15384413](https://i.servimg.com/u/f37/19/56/92/67/15384413.jpg) here are the links ![My monster Murray build 15391411](https://i.servimg.com/u/f37/19/56/92/67/15391411.jpg) here are the links mounted to the original axle ![My monster Murray build 15403611](https://i.servimg.com/u/f37/19/56/92/67/15403611.jpg) here is the axle sitting about where it will be ![My monster Murray build 15493311](https://i.servimg.com/u/f37/19/56/92/67/15493311.jpg) here are the shocks, they came off of an old Suzuki lt125 ![My monster Murray build 15626211](https://i.servimg.com/u/f37/19/56/92/67/15626211.jpg) here are the shocks bolted in ![My monster Murray build 15843911](https://i.servimg.com/u/f37/19/56/92/67/15843911.jpg) here is the panhard bolted in, its going to be a little over 12'' tall [/url] ![My monster Murray build 15844110](https://i.servimg.com/u/f37/19/56/92/67/15844110.jpg) here it is, I still have to do the rear. I plan on locking the MST-205, putting two pillow blocks in for extra support for when I extend the input shaft. ![My monster Murray build 15774810](https://i.servimg.com/u/f37/19/56/92/67/15774810.jpg) making hubs out of the old rims, to mount to the 22 x11 x10 tires ![My monster Murray build 15799810](https://i.servimg.com/u/f37/19/56/92/67/15799810.jpg) here it is bolted in | |
| ![Go down](https://2img.net/i/empty.gif) | | AllisKidD21 Moderator
![My monster Murray build Empty](https://2img.net/i/empty.gif) | Subject: Re: My monster Murray build January 7th 2017, 9:09 am | |
| Looks pretty cool man! How good does the suspension work? Is it stiff? ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| ![Go down](https://2img.net/i/empty.gif) | | AlaskanJoe907 New Member
![My monster Murray build Empty](https://2img.net/i/empty.gif) | Subject: Re: My monster Murray build January 7th 2017, 4:05 pm | |
| Its a little stiff, but I'm not worried about stiffness, as long as it has some, | |
![My monster Murray build Empty](https://2img.net/i/empty.gif) | Subject: Re: My monster Murray build January 7th 2017, 5:10 pm | |
| Nice! I suppose once it's on all fours and driving, the suspension will probably be less stiff. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| ![Go down](https://2img.net/i/empty.gif) | | MatthewD Veteran Member
![My monster Murray build Empty](https://2img.net/i/empty.gif) | Subject: Re: My monster Murray build January 8th 2017, 12:06 pm | |
| Nice build! I like the panhard rod arrangement. How much flex are you looking for? | |
| ![Go down](https://2img.net/i/empty.gif) | | prancstaman Veteran Member
![My monster Murray build Empty](https://2img.net/i/empty.gif) | Subject: Re: My monster Murray build January 8th 2017, 7:16 pm | |
| Nice front end setup. Do the shocks and panhard bar keep the front axle from twisting forward and backward? | |
![My monster Murray build Empty](https://2img.net/i/empty.gif) | Subject: Re: My monster Murray build January 8th 2017, 10:20 pm | |
| The panhard bar is more for making the axle still, so it doesn't move side to side. its not really for flex, just something different then using the stock mower axle setup. This is the second one I'm building, I wasn't on ATLTF.com at the time of me building my first lifted mower. | |
![My monster Murray build Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | My monster Murray build | |
| Who is online? | In total there are 117 users online :: 0 Registered, 0 Hidden and 117 Guests
