| 1975 ford lt75 | |
+2MatthewD WNY-offroad mowers 6 posters | Author | Message |
WNY-offroad mowers New Member
Age : 27 Join date : 2016-10-24 Points : 2961 Posts : 8 Location : Lockport, NY
| Subject: 1975 ford lt75 November 26th 2016, 12:45 am | |
| Ok so I got this Ford LT75 a while back for $50. I did notice that montgomery wards and Jacobsen made this same tractor. Havent really looked at it much because I started a project with a murray widebody lt. Was wondering if anyone has ever modified one of these or has pics of a modified one. dont know if i want to go offroad or kart style with it. Does anyone know what transaxle it has? its a three speed with reverse. Looked all over on google and havent really seen any that have been done so I really have nothing to go off of. Any information is greatly appreciated! | |
| | | | MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| Subject: Re: 1975 ford lt75 November 26th 2016, 6:19 am | |
| Nice! That's a really cute tractor. Does it have the engine mounted sideways? Judging by the shifter, I'd say it is a peerless 600. I wouldn't modify that one too much, just remove the deck, pulley swap, not much more. | |
| Subject: Re: 1975 ford lt75 November 27th 2016, 12:20 am | |
| - MatthewD wrote:
- Nice! That's a really cute tractor. Does it have the engine mounted sideways? Judging by the shifter, I'd say it is a peerless 600. I wouldn't modify that one too much, just remove the deck, pulley swap, not much more.
Yes the engine is mounted sideways, 7hp briggs. I looked today it does in fact have the 600 series trans. I would like to modify it but keep the original paint. I like the stock look. Only things I would want to change is the foot boards, maybe build something around them to keep my feet in. I also worry about pulley swapping due to the width of the machine. it definitely is small and skinny, wish it was a tad wider. Still looking for ideas, it is built like a tank for its size. | |
| | | Doug Site Owner
| Subject: Re: 1975 ford lt75 November 27th 2016, 12:30 am | |
| If it were me, it would be utility. Rather beef it up and use it for work than risk flipping it on a trail. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: 1975 ford lt75 November 27th 2016, 1:36 am | |
| - Doug Fackler wrote:
- If it were me, it would be utility. Rather beef it up and use it for work than risk flipping it on a trail.
was thinking about the utility/ offroad route too, maybe just a slight pulley swap with some more aggressive tires, bumpers, winch, etc. I do want this build to last awhile and the current engine does smoke a bit on startup. So it may need a engine swap in the near future. | |
| | | AllisKidD21 Moderator
| Subject: Re: 1975 ford lt75 November 27th 2016, 8:22 am | |
| It would appear that your 600 has 3-bolt hubs as well, that could open up your choices for rear wheels maybe. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: 1975 ford lt75 November 27th 2016, 8:28 am | |
| 600's are a beefy trans! Esp for a wee 7hp briggs. Maybe an engine swap would be a viable option, depends on how fast you want to go. | |
| | | TheGreenHornet Member
Age : 23 Join date : 2016-04-16 Points : 3416 Posts : 227 Location : Indiana
| Subject: Re: 1975 ford lt75 November 28th 2016, 11:23 am | |
| Arent the 600s horizontal input? And the mower has a vertical shaft engine? that would be a twisted belt. i hate twisted belts. nothing but trouble. for the most part at least. never had to deal with any thankfully, but it just seems like it would be an issue at higher speeds or pulling something, whichever way you go with this. | |
| Subject: Re: 1975 ford lt75 November 28th 2016, 12:22 pm | |
| - TheGreenHornet wrote:
- Arent the 600s horizontal input? And the mower has a vertical shaft engine? that would be a twisted belt. i hate twisted belts. nothing but trouble. for the most part at least. never had to deal with any thankfully, but it just seems like it would be an issue at higher speeds or pulling something, whichever way you go with this.
The 633 is horizontal, I think thats the only one. The rest of the 600s are vertical. @AllisKidD21 used a 600 in his rat rod and @redzz02 used one in his drift missile | |
| Subject: Re: 1975 ford lt75 November 28th 2016, 12:27 pm | |
| Yeah, @Prancstaman has one in his tank. They are have really strong cases and thick axle supports. Pretty good choice for a mudder. | |
| Subject: Re: 1975 ford lt75 November 28th 2016, 4:00 pm | |
| The 633's weren't made by Peerless, that's why they're different. The 600's are pretty heavy duty though, like Matt said they usually have cast axle housings that bolt to the case. They don't have a reverse chain either, they have a reverse idler gear like a car or tractor. They shift on the go really smooth as well, my rat rod shifts like a car and it's pulley swapped. They have an H-shift pattern too which is nice, but it takes a wee bit of getting used to for quick shifts. Oil filled as well which is a bonus. Mines held up great especially considering I had to grind 'er into gear a few times when the clutch stopped working, hahaha! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: 1975 ford lt75 November 28th 2016, 5:15 pm | |
| I think the 633's were made by Roper. The downside is that they only come in 3 speed and reverse models so you don't have that joy of shifting up 5/6 gears | |
| Subject: Re: 1975 ford lt75 November 28th 2016, 5:22 pm | |
| Yeah Roper made 'em. You have a point, but I like the three speed because it's like an old 50's muscle car hahaha! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | | | 1975 ford lt75 | |
