| '71 Gilson Build | |
tater195 Member
| | | | MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| | | | tater195 Member
| Subject: Re: '71 Gilson Build November 24th 2016, 5:32 pm | |
| Nice! That cast iron block briggs will keep the front wheels on the ground ! | |
| | | tater195 Member
| Subject: Re: '71 Gilson Build November 29th 2016, 6:17 pm | |
| Rewire is mostly done. I am still waiting on the voltage regulator, then I can mount the gas tank and battery. It will hit and run if you dump a little gas down its throat, so thats a good thing. then on to tightening up the steering and fab up the missing parts for the brakes
| Subject: Re: '71 Gilson Build November 30th 2016, 12:08 pm | |
| Cool Does it have a 633 transaxle/transmission? | |
| | | tater195 Member
| Subject: Re: '71 Gilson Build November 30th 2016, 3:26 pm | |
| I think it has the peerless 2300 4 speed. I have not got around to that end of it yet. Once I get it running good, I will probably yank the TX and tear it down and give it a good cleaning and fresh oil. | |
| Subject: Re: '71 Gilson Build November 30th 2016, 4:05 pm | |
| Yeah, but they are the same design, right? | |
| | | tater195 Member
| Subject: Re: '71 Gilson Build November 30th 2016, 6:26 pm | |
| basically, kinda sorta but not really. 1 is a 3 speed with hi/lo and the other is a 4 speed and the 2300 has a cast iron case | |
| | | tater195 Member
| Subject: Re: '71 Gilson Build December 4th 2016, 1:58 pm | |
| Rewire is complete and it starts and runs. Starter/ gen is making some weird noises and it doesnt look like it is charging, so that is gonna get rebuilt next | |
| | | | AllisKidD21 Moderator
| Subject: Re: '71 Gilson Build December 4th 2016, 6:07 pm | |
| Is that old S/G a bushing type or does it have bearings? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | tater195 Member
| Subject: Re: '71 Gilson Build December 4th 2016, 6:29 pm | |
| pretty sure it has bearings. Its been awhile since I have been in one of these. | |
| Subject: Re: '71 Gilson Build December 4th 2016, 6:40 pm | |
| If it has bushings there will be little caps you can put oil into. Either way I suppose you might have to rebuild it anyway since it's not charging "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | Doug Site Owner
| Subject: Re: '71 Gilson Build December 4th 2016, 6:45 pm | |
| Those fenders are pretty killer. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Who is online? | In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests
