 Sears Suburban Bogging Mower
moparjim
10 posters
Sears Suburban Bogging Mower Empty
PostSubject: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 27th 2016, 11:11 pm
Sears Suburban Bogging Mower 20160713
Sears Suburban Bogging Mower 20160714
Sears Suburban Bogging Mower 20160715
This is one of my, and most complete, Sears Suburbans. This one has a Kohler K301 which is being removed in favor of a 13hp generator motor due to the 13hp having both pull and electric start. Today I put the AT489s on the front and started on some other small mods. Plans are paint, bumpers, 1:1 ratio pulley swap, Kevlar belt, skid plates, and mounting the hood.
Sears Suburban Bogging Mower 20160716
Plus this is the main reason I'm getting back into mowers, MurrayMayhem recently bought this Troy-Built, with a 3/4" F-N-R and a 25hp Kohler Courage Twin, and got it working with 22" knobbies on the rear and 20" turfs on the front.
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 27th 2016, 11:22 pm
At first I thought it said, sears suburban bogging. Thought we were having running issues. Looks tough with those tires. Should be able to paddle your way through some deep holes with those on there.
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 27th 2016, 11:33 pm
Yeah the rear tires are pretty great, even though they don't hold air they are super hard and are still 26x12x12. They really dwarf the front tires which don't look like 24s on thia
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 28th 2016, 11:58 pm
A bit of progress on the tractor today...
Sears Suburban Bogging Mower 20160717
Then a minor set back
Sears Suburban Bogging Mower 20160718
Sadly all I had time for today was to remove the K301 and start ripping the generator apart. Hopefully more progress tomorrow!
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 29th 2016, 11:44 am
Sears Suburban Bogging Mower 20160719
Might be a sight problem, I've found a tampered to 1" shaft adapter for $60 but I'm not sure I want to fork out that much and might just weld a pulley on there
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 29th 2016, 2:16 pm
What kind of engine is it? Clone?
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 29th 2016, 8:04 pm
Yes it's a 13 hp 'PowerTrain'
Sears Suburban Bogging Mower 20160736
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 29th 2016, 8:19 pm
Another picture of the motor
Sears Suburban Bogging Mower 20160728
Little header I made
Sears Suburban Bogging Mower 20160725
Sears Suburban Bogging Mower 20160727
Beginnings of a bumper
Sears Suburban Bogging Mower 20160735
Some decent welds
Sears Suburban Bogging Mower 20160726
Sears Suburban Bogging Mower 20160720
Sears Suburban Bogging Mower 20160723
Sears Suburban Bogging Mower 20160724
With the prerunner bar bent and welded on
Sears Suburban Bogging Mower 20160722
Sears Suburban Bogging Mower 20160734
By the way the turfs are temporary while I get the AT489 valve put in
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 30th 2016, 1:39 pm
Do you have the other part of the generator? I've heard of people beating the windings off the shaft in the generator part and using the shaft for the pulleys. If you get what I mean.
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 30th 2016, 2:32 pm
Thanks for that Redline, kinda feel stupid for not think king of it myself lol
Sears Suburban Bogging Mower 14699010
Sears Suburban Bogging Mower 14699011
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 31st 2016, 3:58 pm
I found a pulley and mounted it today
Sears Suburban Bogging Mower 20160737
Sears Suburban Bogging Mower 20160739
Sears Suburban Bogging Mower 20160738
Thinking about putting these lights here
Sears Suburban Bogging Mower 20160740
Sears Suburban Bogging Mower 20160741
I am also in the process of tearing this apart for paint. Other than that, I have to slightly modify the clutch to work with the larger pulley, get a belt, mount the gas tank, and build a skid plate.
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 31st 2016, 5:58 pm
Looks pretty mean. I like the front bumper, seems to be lots of room for a winch! Hahaha!
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 31st 2016, 6:39 pm
Cool! Glad to see you got it figured out. Are you just gunna chop that aluminum part off that the generator part bolted to? Or does it unbolt from the block?
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 31st 2016, 8:03 pm
Thank you and yes that's the plan eventually
I'm going to cut off where the belt would contact and use the rest as a belt retainer/splash guard (and it's part of the block).
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 31st 2016, 10:14 pm
If that isnt the most convenient thing ive ever seen haha. Fits the pulley perfect
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 31st 2016, 11:08 pm
When you're building something like this and things just go right, it's awesome.
Everyone loves surprises right?
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeJuly 31st 2016, 11:22 pm
It really is, it only took digging through piles of mower scraps dumped off at MurrayMayhem's house to fine the one pulley that slid perfectly onto the center of the armature stub and was the right size for the case
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeAugust 1st 2016, 11:41 pm
Progress today (even though it looks like it's going backwards)
Sears Suburban Bogging Mower 14701015
Got the case cut to clear the belt (needs a little clearing up)
Sears Suburban Bogging Mower 14701016
Modified the clutch to work with large front pulley, dont know if it'll work good but I can hope
Sears Suburban Bogging Mower 14701017
Finally I mounted a gas tank from a Briggs with a grinder and a lot of zip ties.
Sears Suburban Bogging Mower 14701018
moparjim
moparjim
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeApril 26th 2017, 9:43 am
Awesome rig man, what did you do for front hubs? I'm building a similar rig and plan on using rear 4 or 5 lug wheels on the front of mine as well.
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeMay 16th 2017, 8:08 pm
my front hubs are 12" rims that mounted on a 3/4" transaxle that were garbage except for the center so I cut them and smashed them flat and drilled holes. if I were you I would get a set of five lug hubs for a 1" shafts and put bushings with a 1" od and a 3/4" id which is what I'm eventually doing so I don't eat through spindles
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeMay 16th 2017, 8:14 pm
Also I finally got around to working on this again (I picked it up yesterday from MurrayMayhem's house) and I just painted the frame. It's not dry in the pictures and there was already runs from where the previous owner hand painted it but it's whatever it's just a mower
Sears Suburban Bogging Mower 20170513
Sears Suburban Bogging Mower 20170512
Sears Suburban Bogging Mower 20170511
Sears Suburban Bogging Mower 20170510
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeMay 16th 2017, 9:28 pm
Sweet! Glad to see ya working on this thing again. I wanna see how those Ags do in the mud, those things are wild!
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeMay 16th 2017, 9:39 pm
Ik it has definitely been long enough I've just had AP classes and FFA competitions and truck projects but I finally got back to this. I hope the 25 year old ag tires will keep up but they're super hard, dry rotted and don't hold air so I have a feeling they wont last
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeMay 16th 2017, 9:41 pm
Runs would bug me to no end... lol!
Them ags look mighty fine on the back however... just fill em full of that expanding foam. Sears Suburban Bogging Mower 1098998679
PostSubject: Re: Sears Suburban Bogging Mower   Sears Suburban Bogging Mower Icon_minitimeMay 16th 2017, 9:50 pm
I'll probably go back and fix it eventually but they aren't as bad with the two coats I put on... and either that or I'll finally get some aqua torques like I've always wanted
» 1967 Sears Suburban Mud mower
» Ol' Sears - 1975 Sears Suburban ST/16
» 72 sears suburban
» Is this a sears suburban
» I seem to be new here. 1969? Sears Suburban
