| | I seem to be new here. 1969? Sears Suburban | |
WellThatsSurprising Member
![WellThatsSurprising](https://2img.net/u/2812/37/66/46/avatars/334-51.png)
Age : 27 Join date : 2012-04-30 Points : 4933 Posts : 407 Location : East Bethel, MN
![I seem to be new here. 1969? Sears Suburban Empty](https://2img.net/i/empty.gif) | Subject: I seem to be new here. 1969? Sears Suburban April 30th 2012, 10:21 pm | |
| So here is what I got. A 1969 (i think?) Sears suburban 12 ![I seem to be new here. 1969? Sears Suburban B7jtoz](https://2img.net/h/oi47.tinypic.com/b7jtoz.jpg) Currently split in half cause i'm replacing the pulley on the trans and maybe welding it locked. What else can I do to make it more awesome? | |
| ![Go down](https://2img.net/i/empty.gif) | | Stretch44875 Administrator
![Stretch44875](https://2img.net/u/2812/37/66/46/avatars/314-28.jpg)
Age : 49 Join date : 2012-04-05 Points : 5627 Posts : 959 Location : Mansfield, Ohio
![I seem to be new here. 1969? Sears Suburban Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | WellThatsSurprising Member
![I seem to be new here. 1969? Sears Suburban Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Stretch44875 Administrator
![I seem to be new here. 1969? Sears Suburban Empty](https://2img.net/i/empty.gif) | Subject: Re: I seem to be new here. 1969? Sears Suburban May 1st 2012, 8:55 am | |
| For mud, that should be a decent ride. Locked rear-end, as you said, and some good tires would help. You said pulley, so I'm guessing it is getting speed up some. Wouldn't speed it up a bunch, that is a top-heavy tractor, and would flip easy. On the transmission, I'd install some grease zerks on the axles, just drill/tap the housing where the axle goes through. Then you can pump grease until you get some out the bearings on the ends. Front wheels should already have zerks. Transmission is a gear oil filled unit, so change the oil and it should be good. I'd put a gas pedal on for ease of driving. | |
![I seem to be new here. 1969? Sears Suburban Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Sponsored content
![I seem to be new here. 1969? Sears Suburban Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | I seem to be new here. 1969? Sears Suburban | |
| Who is online? | In total there are 117 users online :: 0 Registered, 0 Hidden and 117 Guests
