 dwcopple's Craft-Rod project [2016 Build-Off Entry]
dwcopple
dwcopple's Craft-Rod project [2016 Build-Off Entry] Empty
PostSubject: dwcopple's Craft-Rod project [2016 Build-Off Entry]   dwcopple's Craft-Rod project [2016 Build-Off Entry] Icon_minitimeMay 14th 2016, 7:26 am
Basically starting with a Craftsman LT1000 lawn tractor chassis and not much else.  I plan on mounting the axle at the furthest front of the frame, but on top of the frame to lower the ride height.  I will be extending the rear of the frame with some box tubing and adding a 3/4 dead axle with a chain drive setup and band brake.  I am thinking powerplant will be a Predator 6.5 hp from Harbor Freight.  I may install a torque converter if funds allow.  Overall build is going to either resemble a rat rod or a 1950's Grand Prix Car.
dwcopple's Craft-Rod project [2016 Build-Off Entry] 20160513_162528_zps4vm60pvb
dwcopple's Craft-Rod project [2016 Build-Off Entry] 20160513_162517_zpshku7ovtd
dwcopple's Craft-Rod project [2016 Build-Off Entry] KIMG0369_zpshko3ysya
dwcopple's Craft-Rod project [2016 Build-Off Entry] 20160513_162534_zpsa4morcf4
» 1997 Murray's DIESEL Craft Quad II [2016 Build-Off Entry]
» MatthewD's Westwood S1200 Build [2016 Build-Off Entry]
» 1984 murray build [2016 Build-Off Entry]
» The SimpleGator [2016 Build-Off Entry]
» jd 214 mudder [2016 Build-Off Entry]
