 Upgrade charging system for winch.
SatiricalHen
SatiricalHen
Upgrade charging system for winch. Empty
PostSubject: Upgrade charging system for winch.   Upgrade charging system for winch. Icon_minitimeApril 25th 2016, 11:51 pm
Does anybody know a way to upgrade a Briggs and Stratton 12.5 charging system to better handle a winch. After using it for almost any amount of time it drains the battery and it won't restart if shut off. Upgrade charging system for winch. Image45
Thanks in advance!
PostSubject: Re: Upgrade charging system for winch.   Upgrade charging system for winch. Icon_minitimeApril 26th 2016, 7:19 am
Install a belt drive alternator.
SatiricalHen
SatiricalHen
PostSubject: Re: Upgrade charging system for winch.   Upgrade charging system for winch. Icon_minitimeApril 26th 2016, 11:14 am
so I should just add a pulley on the top of the engine like fearlessfront's pull start thing and make a bracket to hold the alternator on the side?
PostSubject: Re: Upgrade charging system for winch.   Upgrade charging system for winch. Icon_minitimeApril 26th 2016, 2:57 pm
or use the alt pulley as an idler in the drive belt system.
PostSubject: Re: Upgrade charging system for winch.   Upgrade charging system for winch. Icon_minitimeApril 26th 2016, 6:34 pm
You could possibly do that but might have slippage issues if the belt doesn't wrap far enough around the pulley. I guess most of the time the clutch is engaged even when sitting in neutral, so that wouldn't matter too much.
SatiricalHen
SatiricalHen
PostSubject: Re: Upgrade charging system for winch.   Upgrade charging system for winch. Icon_minitimeApril 26th 2016, 7:10 pm
well my thinking was that mudding with trucks alternators get killed all the time so put it up high so it won't get ruined. Does anyone else have this problem with winches on their mowers?
» charging issue - bad stator or bad battery or both
» Does anyone know what kind of charging system is on this 1995 12HP Briggs?
» Opposed not charging
» Briggs Charging Modification?
» 04' briggs ELS charging issues
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: General Electrical Topics-
