| Some sort of craftsman... and more! | |
+12Crazy_Carl biggasmowers onebadLT4000 RichieRichOverdrive Lawren Wimberly mr.modified Doug MatthewD TheBeal CraftsmanQuad19 AllisKidD21 prancstaman 16 posters |
| Subject: Re: Some sort of craftsman... and more! August 19th 2017, 2:59 pm | |
| - TheBeal wrote:
- AllisKidD21 wrote:
- Looking good Beal. Im assuming those pipes are for some sweet dual exhaust setup?
Uhh... Im not sure we are looking at the same thing... Ah yes, I remembered it cant be dual because the "Craftsman Thing" has a single on it, so many engines in one thread it's hard to keep track haha. So those white pipes arent for exhaust? | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5683 Posts : 1402 Location : Central PA
Age : 25 Join date : 2016-07-10 Points : 8553 Posts : 5190 Location : Ontario Canada
| Subject: Re: Some sort of craftsman... and more! September 1st 2017, 10:09 pm | |
| Nice Beal! Got any plans for that big ol' Kohler once you get 'er running? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Some sort of craftsman... and more! September 3rd 2017, 12:12 pm | |
| Thanks. Im not sure just yet... if it runs there is a potential buyer out there. But I mean like, its a big old 16hp! Do I really want to sell it?? Th guy needs a dual shaft engine for some kind of mower.
A thought is to use it for a... "thing" of some sort, with a 3 speed car trans and cut down rear end. Maybe.
| Subject: Re: Some sort of craftsman... and more! September 3rd 2017, 1:45 pm | |
| I thought we decided an Onan would be the power plant of that project Beal? Haha, but yeah the ol' Kohler would have enough grunt for that job most likely. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Some sort of craftsman... and more! September 4th 2017, 10:53 am | |
| - mightyraze wrote:
- That sounds like an interesting "thing"
Hehehe... yup. Ill have a whole fleet of various "things". "The Craftsman Thing", "The Other Thing", "This Thing", "The Green Thing" and so on... - AllisKidD21 wrote:
- I thought we decided an Onan would be the power plant of that project Beal? Haha, but yeah the ol' Kohler would have enough grunt for that job most likely.
Nothing is set in stone... the possibilities are endless! Maybe Ill use a 330 2cyl 2 stroke! Or 5hp briggs flatty... well... maybe not that small... lolI really need to finish some of this other junk first. lol - mightyraze wrote:
- Onan!? <shivers>
An 18hp unit. Havnt had it running yet... just another iron in the fire. | |
| Subject: Re: Some sort of craftsman... and more! September 4th 2017, 1:28 pm | |
| Cut out a cardboard gasket and put the oil pan on th Kohler. Need a 1/4in pipe elbow for the drain. I thought some 2in angle would be great to make a base for it... Except it dont fit between the sump and shroud. Doah. | |
| Subject: Re: Some sort of craftsman... and more! September 4th 2017, 7:27 pm | |
| Im not sure... my bandsaw is down, that leaves the chop saw for cutting pieces to make the base... but cutting angles with the chop saw can be a pain. Ill make measurements for a base tnite. Maybe put it together this week. Gona park the carb in some cleaner for a few days. This might be a good time to build a small engine test stand. | |
| Subject: Re: Some sort of craftsman... and more! September 4th 2017, 8:07 pm | |
| Put the carb in a can of cleaner. Look what it looks like on the inside. Eww... Ewww... Ewwww... What is the SAND?!?! in teh carb??? Sure looked like it...Anyone know how many seals are in these beggars ill need to replace? Hoping Ill get lucky and wont need much if anything... heres hoping. Ha. | |
| Subject: Re: Some sort of craftsman... and more! September 4th 2017, 8:18 pm | |
| Nice haha, you can tell she sat for a while. I'd see what the needle and seat look like, and try and clean that high throttle jet out real good. Also I'd check to make sure there isn't a hole in the float and replace the bowl seal. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Some sort of craftsman... and more! September 4th 2017, 10:51 pm | |
| Ewww is correct. That sand or fine rust and corrosion? Hope it cleans up well. I like to see you get it running. That's a cool engine. | |
| Subject: Re: Some sort of craftsman... and more! September 5th 2017, 5:40 pm | |
| Probably both. Results of ethanol too maybe? Ill see what it looks like this weekend. Got the oil drain in. maybe not the final position, but close enough. | |
| Subject: Re: Some sort of craftsman... and more! September 7th 2017, 11:03 am | |
| So, back to that gokart... Need to run a jack shaft. They way its going, there will be about 5in of unsupported shaft. Is that gona be a problem? There is 2 pillow blocks to support the shaft. Positions arnt quite set in stone just yet {EDIT}Got the engine mounting plate booger welded to the kart frame. Well, not ALL booger welds...This is right-side up on my computer. Next will be mounting the jackshaft, and engine. I may end up welding another plate to the angle iron, but first will just poke some holes in the angle iron and see how that holds up. | |
| Subject: Re: Some sort of craftsman... and more! September 7th 2017, 6:41 pm | |
| You know... Sometimes, I HATE EVERYTHING... Mounting the engine... measuring, measuring, measuring... and even more measuring. OK. Layout holes and drill. Alright, looks good. Kid of pretty... felling kind of proud. But no. No. NO. It doesnt work... and this is maddening. Seriously. Well I mush have been close... maybe I just need to file the holes some... No. Not even... Well, seeing as how my rage didnt rain fire and brimstone, death and destruction... I drilled some more holes! Yay! [/i] | |
| Subject: Re: Some sort of craftsman... and more! September 21st 2017, 8:11 pm | |
| Yay I did something constructive tnite! Or abusive... man it takes too long to cut 1/4in angle on my chop saw. Wish the band saw was working! Parts to build a base for the K341. Gona try to get it welded up tomorrow... along with another welding project... | |
| Subject: Re: Some sort of craftsman... and more! September 21st 2017, 9:47 pm | |
| Nice Beal! That 1/4" angle steel looks pretty heavy, should be good enough for that ol' shake monster hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Some sort of craftsman... and more! September 22nd 2017, 4:32 pm | |
| Haha, yeah, 1/4 will be more than enough beef. 1/8 could work, but I think 3/16 would have been perfect.
Ill need to be some brackets added to mount the thing... but that will happen when it finds a home. | |
| Subject: Re: Some sort of craftsman... and more! October 4th 2017, 6:43 pm | |
| Chipping away at getting the kohler running... got some grinding to do. Unfortunately, 2in isnt enough to clear the oil drain. I think some thick washers under the engine will fix that. | |
| Subject: Re: Some sort of craftsman... and more! October 21st 2017, 12:04 pm | |
| Got a couple items from an engine show/flea market. This shroud should fit my 11hp briggs. Peerless 700 #2! In all cost $22! Any ideas what this is? Fancy looking breather? I didnt really look that close... | |
