| big tire????? | |
steeldaytonas Member
Age : 41 Join date : 2015-10-23 Points : 3408 Posts : 77 Location : petawawa,Ontario, Canada
| Subject: big tire????? March 29th 2016, 8:33 pm | |
| Im looking to use a set of 33 inch tires on stock lawn tractor locked tranny . Dont ask why it really simple I want to reuse 2 to worn for my trucks and regrove them but I dont want to kill my tranny | |
| Subject: Re: big tire????? March 29th 2016, 8:57 pm | |
| it won't last long if you ride off road or go faster then stock. If you just drive it in parades and stuff like that then it should work, but otherwise I would get a stack of spare transaxles and install them with wing nuts so you can swap them out on the trail quickly, if you are using a 3/4" axle trans. If they are 1" shafts it should last longer. | |
| Subject: Re: big tire????? March 29th 2016, 9:14 pm | |
| it look to answer good . anyone try to get a cromoly axle made to do something like that ??? Just ask!! | |
| Subject: Re: big tire????? March 30th 2016, 10:40 am | |
| If you put a solid axle all the way thru then it would defentately help, because with big tires it would put a lot of stress on the trans housing. if there was something solid all the way thru it would help a lot. | |
| | | | | big tire????? | |
