![All-Terrain Lawn Tractor Forum](https://i.servimg.com/u/f23/18/66/18/00/header10.png)
| | Need help! | |
Keenan123 New Member
![Need help! Empty](https://2img.net/i/empty.gif) | Subject: Need help! March 17th 2016, 7:22 pm | |
| I have a 13hp Horizontal shaft engine it's a "Hy-Spec Hydraulik"(have been told it's the same as a powerfist or whatever) it is pull start only. There is a yellow wire that comes out under the red killswitch. Anyone able to tell me what it's for? | |
| ![Go down](https://2img.net/i/empty.gif) | | mr.modified Veteran Member
Age : 34 Join date : 2013-11-02 Points : 7089 Posts : 2907 Location : New Jersey USA
![Need help! Empty](https://2img.net/i/empty.gif) | Subject: Re: Need help! March 17th 2016, 9:43 pm | |
| Charging coil wire? You would think a pull start engine would be sold without the charging coil, unless they just put them in all models. I've never heard of them before. Tried googling some pics, but couldn't find anything. The wire is just laying loose there? | |
| ![Go down](https://2img.net/i/empty.gif) | | Keenan123 New Member
![Need help! Empty](https://2img.net/i/empty.gif) | Subject: Re: Need help! March 17th 2016, 9:45 pm | |
| Yes... I would post a picture if I knew how | |
![Need help! Empty](https://2img.net/i/empty.gif) | Subject: Re: Need help! March 17th 2016, 10:11 pm | |
| Here's a link to show how to post pics. https://www.atltf.com/t1525-image-posting-for-new-members?highlight=picutre+postingIf you use something like photobucket to store photos, you can just copy and paste the link to here. At any rate, the only other thing I could think it might be is a low oil shut off or something, but that would be in the side of the block. Maybe it just goes to the shut off switch as an extra wire that they don't use in this case. For instance on some models they may have a low oil switch but on this model it isn't used but they use the same wiring. | |
![Need help! Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Need help! | |
| Who is online? | In total there are 23 users online :: 0 Registered, 0 Hidden and 23 Guests
