 Can a mower run under water with a Snorkel?
crafsmankiller
greener179
W1ldyOvvnZ
Chopperhed
Bandit1
canadianromper
CraftsMAN
redzz02
Jordan
Jamus
NZHproduction
blanket80
madmowerz
19 posters
Go to page : Previous  1, 2
CornishMorgan
Can a mower run under water with a Snorkel? - Page 2 Empty
PostSubject: Re: Can a mower run under water with a Snorkel?   Can a mower run under water with a Snorkel? - Page 2 Icon_minitimeFebruary 26th 2013, 5:15 pm
Yeah you can do it with a normal high current switch but doing that means you have a very high current traveling very close to you, if it got wet enough the full current capacity could travel through the water and the second you touch that switch, you'll get fried.
That technically is no reason to use a solenoid. But it's the safest way when dealing with high currents. Remember, It's the Current that harms and kills you, Not Voltage.
PostSubject: Re: Can a mower run under water with a Snorkel?   Can a mower run under water with a Snorkel? - Page 2 Icon_minitimeFebruary 26th 2013, 5:18 pm
Voltage sure stings you tho bounce
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Can a mower run under water with a Snorkel?   Can a mower run under water with a Snorkel? - Page 2 Icon_minitimeFebruary 26th 2013, 5:22 pm
Not really. 12 volts doesnt't have the push to do anything to you. Go outside right now and touch both terminals on your battery at the same time. Nothing will happen. body resistance is 1 mega ohm, then according to ohm's law (V=I*R) it would take much more than 12v to create a dangerous current (I>0.5amp), with that data (V=12v and R=1Mohm) the current would be 0.012mA(0.000012A) and thats definetaly nowhere near dangerous
Last edited by WellThatsSuprising on February 26th 2013, 5:27 pm; edited 1 time in total
PostSubject: Re: Can a mower run under water with a Snorkel?   Can a mower run under water with a Snorkel? - Page 2 Icon_minitimeFebruary 26th 2013, 5:24 pm
I was talking about tazer voltages Smile ea coil. Which I don't remember how high a coil is in Volts, think its 40000v on a winter coil? But low amp.
Last edited by Thunderdivine on February 26th 2013, 5:29 pm; edited 1 time in total
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Can a mower run under water with a Snorkel?   Can a mower run under water with a Snorkel? - Page 2 Icon_minitimeFebruary 26th 2013, 5:28 pm
Ah, ok then.
tractorboy567
tractorboy567
PostSubject: Re: Can a mower run under water with a Snorkel?   Can a mower run under water with a Snorkel? - Page 2 Icon_minitimeFebruary 26th 2013, 6:10 pm
you can but you have to waterproof everything ( carb, electrical, etc...)
» Who has made a snorkel air breather successfully?
» whats the best idea for a snorkel
» has any body put a air snorkel on a 16 b&s twin
» Custom Snorkel for Craftsman
» Water in engine
