 Who has made a snorkel air breather successfully?
akcender
akcender
Who has made a snorkel air breather successfully? Empty
PostSubject: Who has made a snorkel air breather successfully?   Who has made a snorkel air breather successfully? Icon_minitimeDecember 16th 2011, 4:30 pm
who has made a snorkel air breather successfully?
AcreFarm
AcreFarm
PostSubject: Re: Who has made a snorkel air breather successfully?   Who has made a snorkel air breather successfully? Icon_minitimeDecember 16th 2011, 5:05 pm
Like this?
Who has made a snorkel air breather successfully? IM001516
akcender
akcender
PostSubject: Re: Who has made a snorkel air breather successfully?   Who has made a snorkel air breather successfully? Icon_minitimeDecember 16th 2011, 5:38 pm
AcreFarm wrote:
Like this?
yeah just like that. How did you do it?
AcreFarm
AcreFarm
PostSubject: Re: Who has made a snorkel air breather successfully?   Who has made a snorkel air breather successfully? Icon_minitimeDecember 16th 2011, 5:58 pm
I made an adapter for the carb from a PVC cap, and just used a little pipe & an elbow for the rest of it. I found a filter that would fit on top of the PVC and made the top for that from a Briggs piston. The filter is held on by a long bolt that runs down thru the center and threads into a piece of steel inside the pipe.
Who has made a snorkel air breather successfully? IM001212
akcender
akcender
PostSubject: Re: Who has made a snorkel air breather successfully?   Who has made a snorkel air breather successfully? Icon_minitimeDecember 16th 2011, 9:37 pm
Where does your PCV breather go?
AcreFarm
AcreFarm
PostSubject: Re: Who has made a snorkel air breather successfully?   Who has made a snorkel air breather successfully? Icon_minitimeDecember 16th 2011, 10:00 pm
The block vents to a "puke tank" which is also made out of PVC pipe... it has a filter on it, and allows oil & pressure to leave the block and go back in. There is no factory breather.
chopsmith
chopsmith
PostSubject: Re: Who has made a snorkel air breather successfully?   Who has made a snorkel air breather successfully? Icon_minitimeFebruary 24th 2012, 5:00 pm
Nice work
» My crankshaft seal leaks on my 12.5hp briggs vanguard.
» Can a mower run under water with a Snorkel?
» whats the best idea for a snorkel
» has any body put a air snorkel on a 16 b&s twin
» Custom Snorkel for Craftsman
