| Peerless 820 input shaft bearing | |
Mudslinger New Member
Join date : 2015-03-06 Points : 3565 Posts : 12 Location : Jefferson City, MO
| Subject: Peerless 820 input shaft bearing July 19th 2015, 12:21 pm | |
| Does anyone have any tricks for removing the bearing on the input shaft of a peerless 820. It went out and locked the rear end up. I got the seal out on the inside already but the bearing ain't budging. The way it looks is it slides out the inside. | |
| | | Doug Site Owner
| Subject: Re: Peerless 820 input shaft bearing July 19th 2015, 6:48 pm | |
| If you laid it on a flat surface, you could probably pound it out with a bearing race + seal driver, or a socket that is about the same or slightly smaller in diameter than the bearing. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Peerless 820 input shaft bearing July 19th 2015, 7:02 pm | |
| I got it eventually. Used a socket and a lot of pounding and pb. Times like this a hydraulic press sure would be nice. | |
| Subject: Re: Peerless 820 input shaft bearing September 29th 2015, 9:43 pm | |
| Where is the best place to get input shaft bearings. I have one that locked up also because of it. Also has anyone changed from needle bearing to ball bearing. Wondering if they would hold up better. Thanks. | |
| Who is online? | In total there are 39 users online :: 0 Registered, 0 Hidden and 39 Guests
