 Jonny's Mad Max super quick build
jonnya
8 posters
jonnya
Jonny's Mad Max super quick build Empty
PostSubject: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 12th 2015, 4:54 pm
So, here is my daft quick build. I'm certainly not expecting to win with this! Just thought I'd enter so I can share my build experience and get useful feedback from you lot.
Jonny's Mad Max super quick build IMG_0016_1
So the purpose of this build is for a sort of racer for my stag weekend, where I'm planning getting a group of my mates in a field with some mowers and race/have fun/do jumps etc before going to the pub for drinks.
Jonny's Mad Max super quick build IMG_0013_1
So this is the main pile of bits/mower I will be modding. I got the mower of the bay last year for £26. Got it's 7hp Briggs running. I'm swapping the engine for a 12.5 Briggs. Using lots of old school table frame for strengthening the rather flexible chassis.
Jonny's Mad Max super quick build IMG_0017_1
Jonny's Mad Max super quick build IMG_0018
Jonny's Mad Max super quick build IMG_0019
Jonny's Mad Max super quick build IMG_0021
So, first of all pressure washed everything. Then stripped everything.
Jonny's Mad Max super quick build IMG_0022
Dropped in the 12.5 HP
Jonny's Mad Max super quick build IMG_0001_3
The 12.5 is a few inches taller than the 7. So I used some table frame steel to frame up a new seat frame. This is also to make the chassis more rigid.
Jonny's Mad Max super quick build IMG_0002_2
So this is as far AS I got on the first day of building. Pretty it defo isnt! I'm thinking of making this a rather silly build. It has a pretty high centre of gravity so I'm considering putting some anti roll stabiliser wheels on the sides. Or (as the diff seems to have siezed) extending the front and rear track  by10" or so. solid axles. Dunno if I'm honest. Very much make it up as I go along! Watch this space!
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 12th 2015, 8:52 pm
Is there some sort of way to take the engine off?
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 12th 2015, 9:43 pm
Come on red, you just cut then re-weld. Only takes a few minutes. Kind of a neat little mower though. Pretty simple design from the factory, mostly a flat piece of stamped out tin.
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 13th 2015, 1:33 am
Yup, the grey box section frame unbolts.
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 13th 2015, 2:42 pm
Oops, I totally didn't see the bolts in the back lol.
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 15th 2015, 8:40 pm
Welcome to the Build-Off! Sorry I'm late qualifying you, I've been outta town for a few days. Good luck!
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 18th 2015, 5:15 pm
So, not as much progress as I'd have liked this weekend. Did nothing really to the chassis except removing the axle.
I've been on the lathe swapping centres of pulleys for a pulley swap. I seem to have lots of big pulleys and it's easier to cut the centre of a large one to let into a smaller one rather than having to take pulleys to an engineer and paying for a keyway to be cut. Pulleys seem quite expensive in the UK for what there are.
Jonny's Mad Max super quick build IMG_0001_4
Jonny's Mad Max super quick build IMG_0002_3
Here's a close up of the small pulley with new centre. This is now welded up. Will take a pic next time.
Jonny's Mad Max super quick build IMG_0003_4
Jonny's Mad Max super quick build IMG_0004_1
Next thing was trying to get the wheel off the axle. Hours of fun this was! I had all my 'weapons of mass destruction' out on this! Absolutely stuck fast! Even destroying the rim took lots more time than I'd have liked.
So, not much big change on this project. Ihad to wind my neck in a bit as I spent several hours thinking of ways to re-engineer a single speed MTD transaxle onto the back of it. If this wasn't a quick build project I'd have continued. I think the gearing would have been a bit daft though. This would have mainly used up too much time.
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 26th 2015, 5:26 pm
So, some progress today/yesterday. I have welded some 2 x 1 box to the bottom of the chassis to tie the front and back together a little more convincingly. There was defo a good bit of flex in the chassis! Hopefully this' and the seat frame will take the whip out of the chassis.
Jonny's Mad Max super quick build IMG_0002_5
Jonny's Mad Max super quick build IMG_0004_2
Jonny's Mad Max super quick build IMG_0003_5
Here's one of my cats Rory. He's more often than not in the shed whilst I'm working. Somehow he's not the slightest bit bothered when the grinder, welder etc are going!
Jonny's Mad Max super quick build IMG_0006_2
So here is my brake disc carrier. I machined it on my lathe from a piece of 2 inch diameter x 1 inch bright steel bar. This is then welded on to the axle. A bit permanent seemingly but should I need to remove it, which is unlikely, I can machine away the weld on the lathe.
Jonny's Mad Max super quick build IMG_0007_1
So here is the disc in place, but not bolted. The disc is off of a mini moto 5 inch diameter. Dunno if anyone's tried this before - only having one side of the axle braked? Feedback appreciated!
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 27th 2015, 3:55 pm
So a little more progress today. I only had a couple of hours on it today, spent the morning looking for a wedding suit, yay. I must be the only person in the UK wanting a chocolate brown suit! Can't find one anywhere! I digress. So I made a bracket for holding the brake caliper and a centre axle support. I've decided to use the original brake/clutch pedal if I can, and connect a cable to operate the new caliper. This will then cut power to the axle as otherwise half the axle could be under power whilst half is braking. I'll hook up the dinky brake on the gearbox too. Every little helps I guess.
Jonny's Mad Max super quick build IMG_0003_6
As this mower is (supposed to be!) a quick build for a bit of fun for an afternoon with my mates, I'm trying to keep costs down, hence my re-use of the bronze bearings/bushes. There's a little  play, but they'll do. I want to put some triangulation bars from near the axle to the centre of the chassis, tomorrows job!
Jonny's Mad Max super quick build IMG_0002_6
I have pretty much a whole day on this tomorrow, my aim is to have it driving/finished, optimistic I know! Watch this space.
N1ck
N1ck
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 27th 2015, 5:38 pm
you should really put the brake on the diff but too late i guess
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 27th 2015, 7:05 pm
I put the disc on the diff on my rat rod tractor. It works well when both tyres have contact with the ground, but has no effect at all when one of the tyres leaves the ground as the wheels then are free to spin in opposite directions. Ideally I need a disc on both sides of the diff, but there isn't space. Or one on the diff and one on the axle. My plan is that by having a combined clutch/brake pedal, there will be no power going to the axle whenever the brake/clutch is applied.
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 27th 2015, 9:27 pm
Everything looks rigid and should hold up well! Im sure youll work out kinks to make it perform in any conditions/any time you want. Always wanted to build a mega offroad RER just like that classic murray, just because nobody has. Maybe next project.
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 28th 2015, 2:49 pm
I guess the best possible way to do brakes like that would be having a solid axle (or locking your differential). Especially when going fast, braking with an open diff can get sketchy.
Nice build though! I also always wanted to build a cool little RER to rip around on. Got everything I need except the time and money Crying or Very sad
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeMay 29th 2015, 9:02 am
The brake isn't as bad as a pinion brake, but you will be much happier with locking your diff, or solid axle.
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeJune 1st 2015, 1:54 pm
So my plan of getting this finished over the half term term holiday didn't quite work out! Nowt wrong with optimism I guess! I've got as far as reassembling it. I think I'm going to weld the diff up, enough of you have convinced me its a good idea.
I havent any new pictures and I'm not venturing outside as it's 1st June and belting down with rain outside, British summer! I couldn't finish largely due to not having a suitable sized belt for it. I have a collection of 20-30 v belts, all too long or too short! I played around for too long with trying to make it work another way with longer/shorter belts, then decided to buy a belt. A false economy really when the belt was only a few pounds. I've ordered the one I think is the correct size and the next size up/down to be sure! I defo want to have this done and running by the end of the weekend though.
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeJune 1st 2015, 10:38 pm
Hey jonnya, is that a homemade woodstove in that one picture? Tractor is progressing some anyway, rear axle is pretty neat looking.
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeJune 2nd 2015, 1:10 am
Yup that's what keeps me warm in the winter. Made out of an old gas bottle. Kids, don't go grinding into a gas bottle! Even an 'empty one'. DO YOUR RESEARCH FIRST!
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeJune 13th 2015, 4:02 am
So, it's 0844 local time, my other half's out with friends pretty much all weekend which gives me an extra long 'shed ticket'! I think I have everything I need to complete project number 2.
Incidentally, my mower stag weekend is still very much going ahead, a slight change is the event. My friend's dad wasn't too keen on Blokes + Beer + motorised vehicles in his field, so we are going to do the same, but will be more of a time trial. I am building some obstacles: a couple of ramps, a large sheet of plastic + liquid soap for doughnuts, and a see-saw (I think you guys call them teeter-totters?) to drive over. Should still be heaps of fun.
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeJune 14th 2015, 5:19 pm
Neat. You'll look like these guys only on lawn tractors.
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeJune 15th 2015, 1:26 am
A bit like that but not that high!
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeSeptember 1st 2015, 4:06 pm
Update, pics and video of this project coming soon! Soz I aint been on here for ages, been getting married etc!
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeSeptember 1st 2015, 4:12 pm
This build is pretty much complete. Watch this space.
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeSeptember 3rd 2015, 11:48 am
Looking forward to seeing this done Jonny!
jonnya
PostSubject: Finished - ages ago!   Jonny's Mad Max super quick build Icon_minitimeNovember 30th 2015, 6:08 pm
Hi, although I know this isn't really a contender, I'd still like to enter this as its the only one of my 3 projects I actually completed! I don't have any good photos, I can get some at the weekend if needed. It's dark when I get home from work at the mo. I have got a pic of it finished from the summer, July sometime. My Nephew having driven it up a bank in a big puddle.
Jonny's Mad Max super quick build 20150725_1546131
and here is a video of him driving along the same track, listen for the belt slipping when wet! Or just wait till it stops in a puddle..
Check out my fuel tank at the end of the video. It's and old fire extinguisher! I'll be happy if I win 'Best fuel tank'!
Jonny's Mad Max super quick build Pbucket
jonnya
PostSubject: Re: Jonny's Mad Max super quick build   Jonny's Mad Max super quick build Icon_minitimeNovember 30th 2015, 6:35 pm
That was so the wrong video! Soz people.
This is the one to watch. Check out the fuel tank.
» Sears Super 12
» SUPER B - 60 MPH FIELD TRACTOR [2016 Build-Off Entry]
» Mr. Modified's SUPER SNAPPER [2017 Build-Off Entry]
» John Deere "Super 16" [2016 Build-Off Entry]
» Off Road Domination's Sears Super Diesel [2016 Build-Off Finalist]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2015 Archive :: Finalists Archive-
