 6 hp B&S Diamond vert shaft
ironart
6 hp B&S Diamond vert shaft Empty
PostSubject: 6 hp B&S Diamond vert shaft   6 hp B&S Diamond vert shaft Icon_minitimeApril 30th 2015, 10:37 pm
I am not the sharpest tool in the box with small engines, but I have taken a 6 hp B&S Diamond engine from a pressure washer and want to install it in my old JD 100 round fender lawn tractor.  Not a lot of power, but it is only for moving the tractor with occasional trailer, not for attachments.
 Question:
 The engine, being on a shot (Broken pump) pressure washer, it is obviously set to run at a constant speed.  What must I do to set it up for a regular tractor varying throttle use?
        Thanks, ...Ironart
»  Briggs 14 hp vert shaft IC engine Starter drive gear problems
» Vertical Shaft Engine on Horizontal Shaft Mower
» Briggs 18.5 vert opposed proformance engine parts
» Anyone know how to install a pulse fuel pump on my 13 HP diamond performance flathead briggs?
» Vertical Shaft Diesel?
