| | Harbor Freight 90 amp flux wire | |
Guest Guest
![Harbor Freight 90 amp flux wire Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![Harbor Freight 90 amp flux wire Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Guest Guest
![Harbor Freight 90 amp flux wire Empty](https://2img.net/i/empty.gif) | Subject: Re: Harbor Freight 90 amp flux wire November 21st 2014, 9:07 pm | |
| yea i've seen where people say not to use the cheap wire that comes with it and use name brands like u mentioned |
![Harbor Freight 90 amp flux wire Empty](https://2img.net/i/empty.gif) | Subject: Re: Harbor Freight 90 amp flux wire November 21st 2014, 9:22 pm | |
| - MTD2fst4u wrote:
- yea i've seen where people say not to use the cheap wire that comes with it and use name brands like u mentioned
Voice of experience. I was plugging away on a project one day and ran out of wire. Nearly broke, I went out and bought a spool of the cheap stuff. bad move. I burnt MAYBE 2 feet of it, before ripping the spool out of my machine and lobbing it straight into my scrap bin. Garbage. | |
| ![Go down](https://2img.net/i/empty.gif) | | Doug Site Owner
![Harbor Freight 90 amp flux wire Empty](https://2img.net/i/empty.gif) | Subject: Re: Harbor Freight 90 amp flux wire November 21st 2014, 11:27 pm | |
| I use Lincoln Innershield .035 in my machine. Works fine. Just need practice, and shiny contacts. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
![Harbor Freight 90 amp flux wire Empty](https://2img.net/i/empty.gif) | Subject: Re: Harbor Freight 90 amp flux wire November 22nd 2014, 9:40 am | |
| - Doug Fackler wrote:
- I use Lincoln Innershield .035 in my machine. Works fine. Just need practice, and shiny contacts.
I use almost nothing BUT Lincoln Innersheild (WHEN I'm using FCAW). | |
| ![Go down](https://2img.net/i/empty.gif) | | truckin42 Veteran Member
![truckin42](https://2img.net/u/2812/37/66/46/avatars/462-16.jpg)
Age : 26 Join date : 2012-10-04 Points : 5429 Posts : 1070
![Harbor Freight 90 amp flux wire Empty](https://2img.net/i/empty.gif) | Subject: Re: Harbor Freight 90 amp flux wire November 22nd 2014, 12:03 pm | |
| Lincoln wire works good, good solid clean welds but hobalt wire is probably the best wire to use, Its alittle tough to use at frist but once you get the hang of it, it does great, Stronger welds, better penetration, better heat and it has a better flux coating and actually does its job. Lincon wire it good but hobalt is the best. It cost about 5 bucks more but its worth it. | |
![Harbor Freight 90 amp flux wire Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Harbor Freight 90 amp flux wire | |
| Who is online? | In total there are 129 users online :: 0 Registered, 0 Hidden and 129 Guests
