  Briggs Opposed Build 46ci
B440
Frankenvarna
TroyBilt Pony
Moose
Angchor
jamcco
crafsmankiller
21 posters
 Briggs Opposed Build 46ci - Page 4 Empty
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 16th 2015, 5:28 pm
Finally, i win!
 Briggs Opposed Build 46ci - Page 4 10937210
Getting cleaned up.
 Briggs Opposed Build 46ci - Page 4 10934610
I have the block on its side ready for the crank case bolted back on. Can i make a gasket from a sheet of gasket maker?
Also I cannot find chopper sheets for the life of me! Will other metals substitute? And do you have to deck the surface for a head gasket swap?
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 16th 2015, 6:13 pm
If your talking about the gasket around the bottom, which I'm pretty sure you are, then gasket thickness obviously affects crankshaft end play. What I always did is slide the bottom on with no gasket and make sure the crank still has a bit of play. I don't know what the specs are, but all the ones I messed with all had more than enough, even without the gasket. Then I just put a bead of permatex (black silicone) around there. Doesn't have to be super heavy. I usually snug the bolts just a little, let it cure an hour or so, then tighten them up. Probably doesn't make much difference if you just tighten them up right away though. I would let it cure over night at least before you put oil back in it.
As far as head gaskets, I don't know. I would guess that the deck would need to be pretty straight/flat with a harder gasket material. You could just check it with a straight edge. Why use heavier duty gaskets on the thing though? What's wrong with stock gaskets?
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 16th 2015, 7:09 pm
Old ones got ripped up bad taking it apart. someone said they used permatex super 300 for head gaskets and its been going good for 2 years so ill try that. Bottom i think ill use gasket material because like you said crank end play it touchy. i think stock you can move the crank up and down though.
fast adam
fast adam
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 16th 2015, 11:59 pm
You could probably try using shim stock, kinda like the stuff they use in feeler gauges
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 17th 2015, 8:34 am
redlinemotorsportts wrote:
Finally, i win!
Copper sheet? Should be plenty. - And the stock gasket are ultra strong and heavy duty, and also takes up minor flaws so decking isn't needed when torqued down properly. I would'nt use liquid gasket maker on a flathead, the gap will be wrong. So if you do make sure you check the gap after with a string of soldering wire.
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 17th 2015, 9:53 am
Finally, i win!
What's wrong with the head being closer than normal? Plenty of people run thin gaskets or no gaskets.
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 17th 2015, 11:10 am
Finally, i win!
Yeah that's true, But it all needs to be in tune.
fast adam
fast adam
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 17th 2015, 12:30 pm
Well your going to want some sort of head gasket on it or else you wont have any sort of seal just a smaller combustion chamber
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 17th 2015, 1:11 pm
I was going to smooth out the decks with valve lapping compound and then the high temp permatex. I might carve the head out a little.
fast adam
fast adam
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 17th 2015, 3:53 pm
Well if you go through water/mud your heads are going to warp and you will lose your seal,
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 17th 2015, 5:21 pm
It wouldn't hurt to try it. At least with this method, all your doing is making sure all the surfaces are nice and flat. Your not damaging anything, so later if it doesn't work good, you can go back to stock head gaskets if needed no problem. I don't know if water splashing on it would warp it enough to hurt anything with the bolts torqued down. Used to throw snow on air cooled snowmobile engines to cool them down on warm days without an issue. Although I realise without any gasket, there is less room for error. Anyway, gotta get this thing finished so you can start on that Turbo 46CI opposed with all billet ARC parts. Then we might need some copper o-ring head gaskets.
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 17th 2015, 6:37 pm
Yea I don't think it's going to warp much like that. And if it did it wouldn't be hard to fix. And forced induction? Ehhhh....
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 18th 2015, 9:11 pm
Whaaa? Why not, doesn't look too hard to rig up.
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 18th 2015, 9:14 pm
Not pressure lube, and screw eletric oil pumps.
802 Customs
802 Customs
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 18th 2015, 11:07 pm
Whats wrong with electric oil pumps?
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 18th 2015, 11:44 pm
1. Dont have enough money
2. Drain your battery
3. If battery dies you cant even pull start it or youll run the turbo.
4. I dont have enough money, or care to boost something thats gunna be a hassle.
Did i say i dont have money? Laughing
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 19th 2015, 7:40 am
Soo, you don't want my pressure lube engine block anymore?
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 19th 2015, 9:12 am
Nah. I actually bought two more projects so everything else mower wise is in a strict budget.
802 Customs
802 Customs
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 19th 2015, 3:59 pm
You're 45 dollars richer as of Saturday. lol.
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 19th 2015, 7:20 pm
That's probably going into this engine lol. And refilling my mig tank
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 20th 2015, 9:52 pm
Oh, oil for the turbo, forgot about that. No big deal. External oil pump from a car, chain driven to crank with bicycle chain and gears. Either separate oil system or oil from crankcase. Free if you've got junk sitting around. I happen to have several junk bicycles and an oil pump from a ford 460 that was in a 79 pickup.
fast adam
fast adam
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 20th 2015, 10:49 pm
Could you use a stock fuel pump?
802 Customs
802 Customs
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 20th 2015, 11:39 pm
I'm pretty sure you cant use a fuel pump to pump oil.
fast adam
fast adam
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 21st 2015, 8:23 am
I know you can buy cheap pumps that use rubber tubing off eBay or amazon
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 22nd 2015, 11:11 am
What are you going to use for a carb on this thing, Stock? Does it look like the intake manifolds are the same on these 46CI engines as the smaller ones? I know the 40 and 42CI's match up.
PostSubject: Re: Briggs Opposed Build 46ci    Briggs Opposed Build 46ci - Page 4 Icon_minitimeJanuary 22nd 2015, 11:21 am
I can't imagine they are different. And yea I'm just swapping the 16.5s carb and intake over
Page 4 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
» 18HP briggs opposed twin
» Briggs Opposed choke
» 16.5hp Briggs and Stratton opposed
» Briggs Opposed DIY Power Secrets
» Briggs opposed twin problems
