| Vari-Drive Questions? | |
Age : 27 Join date : 2012-10-31 Points : 5164 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Vari-Drive Questions? August 30th 2014, 2:45 pm | |
| HI guys I was wondering if you could put a vari-Drive from a MTD onto a Murray with 5-speed 820 for more of a variable speed setup with out having to have the motor screeming in 5th? or idle the motor while going through a town and not get pulled over for being loud.? or achive a lower speed crawl for off-road?
Any suggestions on how this would work would be appriciated, or a comment on why it won't work.
| | | Doc Sprocket Site VIP
| Subject: Re: Vari-Drive Questions? August 30th 2014, 3:23 pm | |
| For what you're after, I don't think the benefits outweigh the liabilities. It will be difficult to set up properly, require 2 belts, require more maintenance, and you'd probably have to regear anyways. | |
| | | TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5717 Posts : 1402 Location : Central PA
| Subject: Re: Vari-Drive Questions? August 30th 2014, 6:49 pm | |
| Note Doc didnt say DONT try it. Would be interesting to see how it turned out. | |
| | | Ariens YT11 Established Member
| Subject: Re: Vari-Drive Questions? August 30th 2014, 7:57 pm | |
| Well I would need a 96" belt if I just did a pulley swap, if I did the Vari-Drive that would be cut in half and there fore belts would be cheaper to buy.
| Subject: Re: Vari-Drive Questions? August 30th 2014, 8:18 pm | |
| - TheBeal wrote:
- Note Doc didnt say DONT try it. Would be interesting to see how it turned out.
Absolutely. I don't think it's particularly practical, but hell- give it a shot. Could work out for ya, you never know. | |
| Subject: Re: Vari-Drive Questions? August 31st 2014, 8:23 am | |
| You need a pivot point for the clutch, linkage with slots for llimiters of how much the clutch moves, spring, flat idler tentioner for the rear belt, and a pulley up front that can accept 5/8" belts. | |
| Subject: Re: Vari-Drive Questions? August 31st 2014, 11:40 am | |
- You need a pivot point for the clutch, linkage with slots for llimiters of how much the clutch moves, spring, flat idler tentioner for the rear belt, and a pulley up front that can accept 5/8" belts.
Does the front pulley need to be 5/8"? if is the pulley's I got should be able to hold them. I was gonna steal the parts from the MTD to make this work if I need to. | |
| Who is online? | In total there are 73 users online :: 0 Registered, 0 Hidden and 73 Guests
