![All-Terrain Lawn Tractor Forum](https://i.servimg.com/u/f23/18/66/18/00/header10.png)
| | vari drive + transaxle | |
fast adam Member
![fast adam](https://2img.net/u/2812/37/66/46/avatars/1858-38.jpg)
![vari drive + transaxle Empty](https://2img.net/i/empty.gif) | Subject: vari drive + transaxle November 16th 2014, 8:59 pm | |
| i recently acquired a yard machine with a vari drive in it and im thinking about putting a 6 speed transaxle in it so then it will have a 42 speed tractor it will be un-pully swapped and im looking for any tips/estaments on the top speed if i get enough interest in it i will build it, so any help would be greatly appreciated (i got the idea from fearless front + i don't have know if anyone has done it before) | |
| ![Go down](https://2img.net/i/empty.gif) | | Carshowkid Member
![Carshowkid](https://2img.net/u/2812/37/66/46/avatars/1859-82.jpg)
Age : 25 Join date : 2014-07-22 Points : 4097 Posts : 347 Location : Downers Grove Illinois
![vari drive + transaxle Empty](https://2img.net/i/empty.gif) | Subject: Re: vari drive + transaxle November 16th 2014, 9:55 pm | |
| I would try to help you since I have a mtd w/ Vari drive... But I have no clue about gear ratios... Heck I have only drove my mtd once for about a min | |
| ![Go down](https://2img.net/i/empty.gif) | | fast adam Member
![vari drive + transaxle Empty](https://2img.net/i/empty.gif) | Subject: Re: vari drive + transaxle November 16th 2014, 10:04 pm | |
| Ya with the vari drive there's only f-n-r so I should figure out the ratio of the transaxle I think its probably the same as the 6-speed in 6th gear It should have alot of speed ranges | |
![vari drive + transaxle Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | fast adam Member
![vari drive + transaxle Empty](https://2img.net/i/empty.gif) | Subject: Re: vari drive + transaxle November 16th 2014, 10:25 pm | |
| Now what I'm wondering is, does the vari drive act like a governor/torque converter like if you go uphill | |
![vari drive + transaxle Empty](https://2img.net/i/empty.gif) | Subject: Re: vari drive + transaxle November 16th 2014, 10:35 pm | |
| - fast adam wrote:
- Now what I'm wondering is, does the vari drive act like a governor/torque converter like if you go uphill
i don't think so... But don't quote me on that... cause I'm not sure. | |
![vari drive + transaxle Empty](https://2img.net/i/empty.gif) | Subject: Re: vari drive + transaxle November 16th 2014, 11:33 pm | |
| I don't think so on second thought because it works by clutch movement and belt tension | |
| ![Go down](https://2img.net/i/empty.gif) | | Thunderdivine Veteran Member
![Thunderdivine](https://2img.net/i/fa/i/avatars/gallery/Cine_Seigneur_des_anneaux/Lotr_129.jpg)
Join date : 2012-12-21 Points : 6469 Posts : 2101 Location : Norway, Europe
![vari drive + transaxle Empty](https://2img.net/i/empty.gif) | Subject: Re: vari drive + transaxle November 17th 2014, 11:43 am | |
| Ya mine is just like that but a few years older. Mine has f-n-r on a panel between my legs si it would be very easy to put in a 6-speed | |
![vari drive + transaxle Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | vari drive + transaxle | |
| Who is online? | In total there are 132 users online :: 1 Registered, 0 Hidden and 131 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
