 Offroad Craftsman Backyard Build
Angchor
Craftsman1998
CornShuck4CE
chevyguy7783
10 posters
chevyguy7783
chevyguy7783
Offroad Craftsman Backyard Build Empty
PostSubject: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeAugust 27th 2014, 10:13 pm
Well here's where I'll be showing my slow build of a 90s Craftsman 12hp 6 speed. Runs but surges even after carb clean and fuel filter change, any ideas why? Not a big deal it still runs great. Also, i'm pretty sure it just needs a new belt, but just in case, why does the clutch have to be like 90% out to start to engage?
Anyway, today was the first day I really did anything to it since I got it last week for $50.
Just for fun I ground down the bump stop on the front axle on the left side and a little on the piece mounted to frame and it probably got another almost 1'' of flex. I have another axle off a Yard Machines if I mess with this one too much. Also took the seat off the YM since it has a higher back (I'm 6' 1") and only has a minor crack. Had to mount a little closer since the bolts line up different from the one it had and they sat crooked on the springs but it works for now.
Also, I'm obsessed with seeing 4 wheeled anything flex so be prepared for all the pictures over time.
Day I got it
Offroad Craftsman Backyard Build DEYZHyp
Changing fuel filter and cleaning carb bowl
Offroad Craftsman Backyard Build VUc6L5l
That stock flex though
Offroad Craftsman Backyard Build RGc3dfF
New vs. Old seat
Offroad Craftsman Backyard Build S23WweJ
Front axle dropped
Offroad Craftsman Backyard Build G3WWbbe
Axle ground down
Offroad Craftsman Backyard Build YgI81bB
CornShuck4CE
CornShuck4CE
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeAugust 27th 2014, 11:20 pm
Check out redlinemotorsport his mtd. He is a flex freak to. Haha. The serge is most likely in the idel speed needle try ajusting it
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeAugust 28th 2014, 10:30 pm
Looks pretty good. Next upgrade is to paint the valve cover a really bright color. As far as the clutch being way out, maybe the belt is streached a little or worn. I'd just let it go if it doesn't bother you too much. The surge may be adjustment or sometimes you miss something when you clean the carb out.
chevyguy7783
chevyguy7783
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeAugust 28th 2014, 10:47 pm
Haha why the valve cover? If anything probably Chevy orange and ya thats what I figured with the belt, its fine until I wanna slowly crawl something to be able to ride the clutch ya know? and I only dropped the bowl to try that first before I undo the whole thing
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeAugust 29th 2014, 3:56 am
I have no idea what you are talking about. lol.
Nice start. Gas petal, bumpers, pulley swap, and tires are all cool things to do. Depending on what route you go.
Craftsman1998
Craftsman1998
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeAugust 29th 2014, 7:17 am
New vs. Old seat
Your dogs photobombing lol
chevyguy7783
chevyguy7783
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeAugust 29th 2014, 5:05 pm
Ya hoping to do gas pedal and brake lever in very near future since i cant stop unless I use reverse right now. and ya he's pretty good at that lol
Used it to move a snowmobile today to get to camper. 6th gear clutch dump and she was pullin'. Front end was a little light lol!
Offroad Craftsman Backyard Build IiENczt
chevyguy7783
chevyguy7783
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 3rd 2014, 9:02 am
Wellllll yesterday had her running for a little bit and right before I parked it, it was making a weird popping sound, so I shut it off and went to start it and now it won't start. I tried starting fluid in carb and in plug hole and still nothing. It is getting spark. Just took shroud off flywheel and spun it and it spins with almost no compression so I think it blew the rings. But it wasn't blowing white smoke or anything? And it has plenty of oil in it
Angchor
Angchor
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 3rd 2014, 2:32 pm
You were pulling from a high point on the rear of the tractor.
Use the plate at the bottom that has the hole, and the front end won't seem so 'light'.
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 3rd 2014, 3:35 pm
^^Wheres the fun in that? lol!
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 3rd 2014, 3:58 pm
thats OHV right? check your valve lash and push rods
chevyguy7783
chevyguy7783
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 3rd 2014, 9:25 pm
the chain had hooks on both ends and they fit perfectly on the top of the back plate thing above the hitch so it worked and thebeal, right?? haha
ya I think it is I have classes all day tomorrow so absolute earliest to look at it is probably gonna be friday or saturday
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 4th 2014, 10:47 am
higher you hook the more traction you get Very Happy which is sometimes too much Shocked Laughing
chevyguy7783
chevyguy7783
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 5th 2014, 10:48 am
So the exhaust rocker was very loose, tightened it up to .004, which I found in an online manual for this engine. It still wont start even with starting fluid, its getting gas, but it still seems like it turns over by hand too easy. Also after holding the key to start and letting go I can hear a little pressure that sounds wet coming out of the carb (I have the filter off). If that makes any sense
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 5th 2014, 11:11 am
maybe check the intake rocker
chevyguy7783
chevyguy7783
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 5th 2014, 11:12 am
I checked that also it was very close to what it should be. I kept the valve cover off and cranked it a few times and both move fine, no binding or anything
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 5th 2014, 11:23 am
im thinkin the valve is stuck or your headgasket is bad. on ohvs the gaskets do that alot, especially briggs engines.
chevyguy7783
chevyguy7783
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 5th 2014, 11:27 am
its a 12 HP tecumseh, best i could come up with was Tecumseh 143-406012 off google.
Just tried a compression tester and it didn't even read anything. Oil might have a gas smell but I can't tell too much since I've never actually experienced it before. Next step would be take the head off?
Angchor
Angchor
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 5th 2014, 12:41 pm
Remove the rockers and see if you can spin the valves.
PostSubject: Re: Offroad Craftsman Backyard Build   Offroad Craftsman Backyard Build Icon_minitimeSeptember 5th 2014, 1:55 pm
pour a little bit of oil into the spark plug whole and spin it over a few times and then check for compression. it sounds like you might have washed the rings down.
» Craftsman "not sure of name yet" offroad build
» OFFROAD Craftsman LT4000-2 mudding mower (MTD12HPTURBO)
» 2nd Generation Craftsman Lt1000 Offroad Build - (Pics)
» '06 Craftsman Offroad Tractor
» Murray offroad mower build
