 The grinch build
CraftsMAN
CraftsMAN
The grinch build Empty
PostSubject: The grinch build   The grinch build Icon_minitimeAugust 27th 2014, 12:52 am
Well it has been a while since I have been on here. Anyone looking for a good step by step build on how to lift a monster mower check out my tube channel zjbeast. Anywhere here are some photos to share..
The grinch build 222aer10The grinch build 2dg10The grinch build Aergrg10The grinch build Ewf11
https://www.facebook.com/CRUSHEMCustoms/
PostSubject: Re: The grinch build   The grinch build Icon_minitimeAugust 28th 2014, 11:12 am
Got any pics of that suspension at work?
CraftsMAN
CraftsMAN
PostSubject: Re: The grinch build   The grinch build Icon_minitimeAugust 29th 2014, 1:22 am
The only problem I have yet to overcome is when I flex it makes the steering rod want to pop off. It still does flex a lot but not full. I was thinking of extending the steering part that sticks out through the frame to meet up with the steering arm that goes to the front axle... Unsure. I have also got an idea to make the rearend flex also but a telescoping drive shaft from the pulley I have yet to figure out how to make.. Very Happy Very Happy Very Happy
MoMower
PostSubject: Re: The grinch build   The grinch build Icon_minitimeAugust 29th 2014, 10:21 am
Drive shaft could just be as simple as 3/4" tubing going to rearend and. 1" tubing to the front. Just like a bushhog's powershaft. That's basically all an automotive drive shaft is. Plus the bushings and seals. But thickwalled tubing should work. Just put a zerk fitting in it. Or take it apart and grease it when needed.
CraftsMAN
CraftsMAN
PostSubject: Re: The grinch build   The grinch build Icon_minitimeJanuary 27th 2017, 1:37 pm
The grinch build 33f4r312 Here is a photo of one of them flexin a little
The grinch build
» future build off mower project build ( unique build )
» bow tie mud guy thrasher build - build #1 [2017 Build-Off Entry]
» [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]
» [DNF][2020 Build-Off Entry] Mini Back yard basher build
