| 18hp cant get gas ! | |
murrey and me New Member
Age : 24 Join date : 2013-06-02 Points : 4206 Posts : 7
| Subject: 18hp cant get gas ! August 3rd 2014, 11:38 am | |
| i haev a 18hp and i cant get it to run from the tank its on a widebody so the gas tank is lower than the engine what r some ideas on how to get it to work?
thanks | |
| Subject: Re: 18hp cant get gas ! August 4th 2014, 12:55 am | |
| - murrey and me wrote:
- i haev a 18hp and i cant get it to run from the tank its on a widebody so the gas tank is lower than the engine what r some ideas on how to get it to work?
thanks Is it a opposed twin? They have fuel pumps, so if you have one, the diaphram is clogged up and needs to be replaced or cleaned, its the plate on the carb outside with 3-4 screws, be careful, little springs behind it. If it isnt a twin with a fuel pump, you can buy a universal pump and use the valve covor pressure. | |
| | | kieranruffell Member
Age : 24 Join date : 2014-01-22 Points : 4011 Posts : 43 Location : Whangarei, New Zealand
| Subject: 18hp cant get gas ! August 4th 2014, 12:58 am | |
| You could possibly relocate your fuel tank so that it is higher than you carburetor. | |
| Who is online? | In total there are 24 users online :: 0 Registered, 0 Hidden and 24 Guests
