| Craftsman Mudder | |
PA Mudder New Member
| Subject: Craftsman Mudder Mon 05 May 2014, 8:36 pm | |
| Hi guys I got a craftsman lt1000 that I trash picked for free and when I got it home it fired right up. The front axle was cracked in several places I welded it up for temporary use so I could test out other parts of the tractor. I swapped out the standard 9inch pulley for a 3inch pulley and got a new belt. I also added a throttle off of a weed wacker to the side shifter. Next I braced up the rear where the trans is so it would reduce the flexing. I also shortend the steering wheel a 1 1/2 because I thought it was too high. I took it drifting on a wet field and broke the ball joint on the drag link and it couldn't be repaired. I found a new drag link, front axle and gas tank because it was cracked so I just have to replace the parts. That is all I did so far in a couple of days I'm going to rewire the tractor and take out all of the safety's. Stay tuned for more. | |
| | | camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4576 Posts : 467 Location : Greensburg, PA
| Subject: Re: Craftsman Mudder Mon 05 May 2014, 8:49 pm | |
| First off, Welcome! I see your from PA, im below pittsburgh in Westmorland County, where you located? | |
| Subject: Re: Craftsman Mudder Mon 05 May 2014, 9:07 pm | |
| I live in Warminster it's in the bucks county area about a 1/2 hour from Philly | |
| | | camomanusa Member
| Subject: Re: Craftsman Mudder Wed 07 May 2014, 8:23 am | |
| just got the tractor rewired last night and hooked it up to a push button start and a double toggle switch for the kill and for the carb plunger I could of cut the plunger but I would rather not | |
| | | Speedfreek241 Member
Age : 26 Join date : 2013-07-11 Points : 4326 Posts : 137 Location : Loxahatchee
| Subject: Re: Craftsman Mudder Wed 07 May 2014, 8:37 am | |
| Glad to see your making good progress on this. You've already got more done on this mower than I have on a few of mine in 3 years. | |
| Subject: Re: Craftsman Mudder Wed 07 May 2014, 1:26 pm | |
| yeah I just got mine a month ago I can't wait to go muddin | |
| Who is online? | In total there are 11 users online :: 1 Registered, 0 Hidden and 10 Guests MightyRazeMost users ever online was 412 on Sat 07 Jan 2023, 6:59 am |
