| Project Corbett buggy | |
+5mudmonkey06 k2500life willis923 CHEVYKID Speedfreek241 9 posters |
| Subject: Re: Project Corbett buggy May 1st 2014, 10:23 am | |
| - k2500life wrote:
- We put all the solenoids and such on the deck, and silicon rant thing else, and usually not higher than the flywheel but really depends
That shrink wrap stuff helps water proof it too | |
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5368 Posts : 1135 Location : Southern Florida
Speedfreek241 Member
Age : 26 Join date : 2013-07-12 Points : 4326 Posts : 137 Location : Loxahatchee
| Subject: Re: Project Corbett buggy May 1st 2014, 10:54 am | |
| Also putting some Greece in the plug boot and wires helps to. Plus I may never go above the flywheel because I don't want to risk anything. | |
Age : 25 Join date : 2013-04-05 Points : 4959 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: Project Corbett buggy May 1st 2014, 10:56 am | |
| - Speedfreek241 wrote:
- Also putting some Greece in the plug boot and wires helps to.
I haven't heard that one, I'll have to try it... | |
| Subject: Re: Project Corbett buggy May 1st 2014, 10:59 am | |
| Yeah sorry you use lithium grease and it helps. Couldn't think of what is was called. I use it on my atvs for when I go in deep water. | |
| Subject: Re: Project Corbett buggy May 2nd 2014, 10:12 am | |
| I got all of my metal for my railings, bumper, and seat so if the weather holds up I can finish all of that later and start cutting wood for the deck so I can mount the seat and consul. | |
| Subject: Re: Project Corbett buggy May 3rd 2014, 3:15 pm | |
| Got all but 3 of my railing uprights in and bent up the railing. Mother Nature isn't on my side right now so I can't finish but if it lets up I will try. | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4576 Posts : 467 Location : Greensburg, PA
| Subject: Re: Project Corbett buggy May 3rd 2014, 7:41 pm | |
| Thanks this rain has been keeping me from building and stopping me from taking my dragster out to the track. | |
camomanusa Member
| Subject: Re: Project Corbett buggy May 3rd 2014, 9:55 pm | |
| This is an action shot of it. Forgot to say it's a half scale but still does 0-60 in 2.6 seconds and I'm only aloud to run 7.90 at 85 mph in the 1/8 mile. There a lot of fun but at 16000 starting cost and $7 a gallon for methanol and burning a gallon in four passes it gets expensive quick. Plus you have to pay for entree fees and constant oils changes. But it is one of the only way a 8-16 y/o kid is strapping into a drag car legally | |
| Subject: Re: Project Corbett buggy May 4th 2014, 9:16 pm | |
| Ok back on topic. I got all my railing tacked in and my bumper tacked. I messed up a bit in the front with the angle but I'll probably just leave it. Next time I get to work I'm going to install my deck and consul so I can build my seat. | |
| Subject: Re: Project Corbett buggy May 6th 2014, 8:39 pm | |
| Well today I got a little more done by cutting and putting on the deck and mounting the engine on better. Still need to trim and paint the deck before it's fully done and ready to be bolted on. I'm coming really close to my deadline to get this thing done by May 22 to take it on a trip and I think I'm not going to make it or it's going to be really close. | |
| Subject: Re: Project Corbett buggy June 16th 2014, 11:00 pm | |
| Well I'm back at working on this thing again. I got the seat mounted, steering in, and got my headlights drilled in and ready to be finished once I get a battery in. I still need to run my shifter and clutch but that should only take a day to do. I found some diamond plate that a neighbor was throwing out that used to be a bed topper for a truck to cover some of the buggy, the rest I'm going to do black carpet or something else on it. | |
CHEVYKID Member
Age : 29 Join date : 2013-09-13 Points : 4121 Posts : 34 Location : loxahatchee florida
willis923 Veteran Member
