| Getting Started on the Murray | |
+5redlinemotorsportts Johndeere12@ camomanusa lincolnmaniac MurryMaddnes 9 posters |
MurryMaddnes Member
![MurryMaddnes](https://2img.net/u/2812/37/66/46/avatars/1621-0.jpg)
Age : 38 Join date : 2014-03-24 Points : 3861 Posts : 32 Location : Green Bay Wisconsin
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Getting Started on the Murray April 12th 2014, 11:29 pm | |
| I am not sure what year this mower is. I do know that it has a 16h B&S with a 42 inch cutting deck that is currently not attached, it also came with a snow blower attachment. The transaxle is a peerless 2348 which I will probably keep for now. What I plan on doing to it this spring. Pulley Swap Lock Transaxle 4 inch lift to accommodate larger tires replace steering rag with steering u-joint custom glass pack exhaust custom gas peddle relocate brake peddle lay some new paint This winter I plan of ripping it down and doing the following. Replace transaxle Leaf spring suspension on the front end. ![Getting Started on the Murray 7p10](https://i.servimg.com/u/f55/18/82/15/20/7p10.jpg) ![Getting Started on the Murray 5p10](https://i.servimg.com/u/f55/18/82/15/20/5p10.jpg) ![Getting Started on the Murray 4p10](https://i.servimg.com/u/f55/18/82/15/20/4p10.jpg) ![Getting Started on the Murray 2p10](https://i.servimg.com/u/f55/18/82/15/20/2p10.jpg) ![Getting Started on the Murray 1p12](https://i.servimg.com/u/f55/18/82/15/20/1p12.jpg)
Last edited by MurryMaddnes on April 13th 2014, 8:02 am; edited 1 time in total | |
lincolnmaniac New Member
Age : 53 Join date : 2014-03-24 Points : 3841 Posts : 18 Location : Tremont Pa.
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | |
MurryMaddnes Member
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Re: Getting Started on the Murray April 13th 2014, 12:06 pm | |
| Yah I still have to finish the bumper, figured I would lay it out and get a few pictures of progress. I work in a metal shop and operate lasers and waterjets so I have easy access to metal. The bolt hole plates to mount the tires that I made last week took a matter of minutes to draw up and cut on my machine.
Are there any suggestions or ideas that you guys think I should do or would be a better option than what I currently am thinking of doing. | |
MurryMaddnes Member
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Re: Getting Started on the Murray April 13th 2014, 12:12 pm | |
| For now this is what I was thinking of for a tire set up, basically what I had lying around in my basement. The rear tires that were originally on the lawnmower will be moved to the front and a set of quad tires will be put on the back. Both will require custom mounting plates to mount to the lawnmower without having to weld them on. I want to be able to change them with ease. ![Getting Started on the Murray Murry110](https://i.servimg.com/u/f55/18/82/15/20/murry110.jpg) | |
camomanusa Member
![camomanusa](https://2img.net/u/2812/37/66/46/avatars/1098-34.jpg)
Age : 25 Join date : 2013-09-15 Points : 4505 Posts : 467 Location : Greensburg, PA
MurryMaddnes Member
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Re: Getting Started on the Murray April 13th 2014, 1:55 pm | |
| Not sure yet, any suggestions I am looking to get as much speed out of it as possible, so I can just blast through the mud. Any suggestions at all will be welcomed because this is my first build. | |
Johndeere12@ New Member
![Johndeere12@](https://2img.net/u/2812/37/66/46/avatars/1669-29.jpg)
Age : 27 Join date : 2014-04-13 Points : 3802 Posts : 1 Location : Mt. horeb w.i
MurryMaddnes Member
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Re: Getting Started on the Murray April 13th 2014, 10:41 pm | |
| Metal shop sounds very handy. Nice murray, has a good trans in it, oil filled, bearings, iron case. | |
MurryMaddnes Member
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Re: Getting Started on the Murray April 13th 2014, 11:11 pm | |
| working in a metal shop has been very helpful not only in planning this project but others that I have worked on, and the trans does seem to be in pretty good shape, going to rip it down and go through it to make sure everything is in proper working order before I take it out on the trail and beat the ever living snot out of it. | |
MurryMaddnes Member
![kawasaki220](https://2img.net/u/2812/37/66/46/avatars/1444-36.jpg)
Age : 23 Join date : 2014-01-22 Points : 4497 Posts : 546 Location : north carolina
83ratrodmurray Member
![83ratrodmurray](https://2img.net/u/2812/37/66/46/avatars/1005-59.jpg)
Age : 28 Join date : 2013-07-05 Points : 4218 Posts : 94 Location : Kentucky
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Re: Getting Started on the Murray April 17th 2014, 8:41 pm | |
| I have a murray just like that but mine doesn't have that belt driven thing by the shifter what is that? | |
MurryMaddnes Member
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Re: Getting Started on the Murray April 17th 2014, 9:02 pm | |
| Well to my understanding that pulley is attached to an alternator that feeds a voltage regulator and charges the battery while the motor is running. But I could be wrong.
richie thomas Veteran Member
![richie thomas](https://2img.net/u/2812/37/66/46/avatars/156-8.jpg)
Age : 29 Join date : 2011-08-04 Points : 6326 Posts : 1434 Location : east dublin georgia
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Re: Getting Started on the Murray April 17th 2014, 9:19 pm | |
| the thing by he battery is a ragb, it allows the vertical shaft engine to run the horizontal shaft tranny with out twisting the belt
MurryMaddnes Member
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Re: Getting Started on the Murray April 17th 2014, 10:14 pm | |
| hahah thanks that makes more sense then what I was told. Thanks Richie
oh I think I figured out how I am going to route the brake, I am going to mount it on the right fender and use a custom parking brake lever that way I can lock the brake when need be. | |
MurryMaddnes Member
![Getting Started on the Murray Empty](https://2img.net/i/empty.gif) | Subject: Re: Getting Started on the Murray April 29th 2014, 10:25 pm | |
| Well this coming up weekend I will be welding up the front bumper, building luggage rack to mount on the rear, installing gas peddle, figure out where I am going to relocate brake lever, and weld up rims and plates so that I can put my tires on. | |
![craftsmancole](https://2img.net/u/2812/37/66/46/avatars/817-65.jpg)
Age : 25 Join date : 2013-04-05 Points : 4888 Posts : 661 Location : New Smyrna Beach,Fl
MurryMaddnes Member
