| opposed twin won't idle. | |
TokyoDrift99 Member
Age : 25 Join date : 2014-03-28 Points : 4030 Posts : 111 Location : Vermont
| Subject: opposed twin won't idle. April 11th 2014, 5:40 pm | |
| Hey guys, I got a briggs opposed twin running that has been sitting for a number of years. The second time I started it the engine ran shoddy, but I could drive it around and such. It just randomly died, and now every time it starts it will fire up, rev REALLY high and die. If I modulate the choke I got it to idle for about 30 seconds. What can I do??? (I have cleaned the carb, and the gas is relatively fresh.) | |
Age : 27 Join date : 2013-03-18 Points : 7479 Posts : 3131 Location : raleigh nc
Age : 28 Join date : 2013-04-10 Points : 5757 Posts : 1408 Location : Galway NY
| | | | Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6539 Posts : 2101 Location : Norway, Europe
| Subject: Re: opposed twin won't idle. April 11th 2014, 9:05 pm | |
| I would clean the carb again, let it soak in fresh petrol for an hour or so. If everything was A ok before it started running on choke only. | |
| | | TokyoDrift99 Member
| Subject: Re: opposed twin won't idle. April 11th 2014, 10:00 pm | |
| I don't think it is starving for fuel, when I first turned it over fuel shot out the line coming from the pump. I will check when I get home though. I don't know about cleaning the carb though, I was really thorough on the inside, I used almost half a can of gumout. | |
Age : 34 Join date : 2013-11-02 Points : 7165 Posts : 2910 Location : New Jersey USA
| Subject: Re: opposed twin won't idle. April 12th 2014, 12:08 am | |
| Sometimes when you clean out a carb, you miss a small opening somewhere or don't take something apart that you didn't notice at first. Make sure to check everything closely. Also it is possible to have the mixture set wrong and have trouble when you think it's ok. I'm in the process of cleaning out some motorcycle carbs and I soaked them in carb cleaner the first time and the bike wouldn't run. Then I realized that the idle mixture screws are covered with a plug so that no one trys to adjust them after it leaves the factory. Once I drilled out the plugs and recleaned them, the bike runs. (Although it still didn't run perfect, and now I'm cleaning them again to really make sure I've got them) But that's besides the point. Your best bet would probably be to re-clean the carb and then give it another shot. | |
| | | TokyoDrift99 Member
| Subject: Re: opposed twin won't idle. April 12th 2014, 10:18 am | |
| I'll mess with the mixture today, but if that doesn't do it I'll clean the carb again. | |
| | | TokyoDrift99 Member
| Subject: Re: opposed twin won't idle. April 12th 2014, 2:27 pm | |
| so now gas is shooting out of some hole on the top of the carb, and it is kind of spraying gas out the choke. What gives? | |
| Subject: Re: opposed twin won't idle. April 12th 2014, 2:42 pm | |
| - TokyoDrift99 wrote:
- so now gas is shooting out of some hole on the top of the carb, and it is kind of spraying gas out the choke. What gives?
When you had it apart and during assembly, did you see and pay attention to the tiny hole on one side but missing on the other side of the gasket? (just throwing out ideas here) - Well many put it the wrong way. | |
| | | TokyoDrift99 Member
| Subject: Re: opposed twin won't idle. April 12th 2014, 3:31 pm | |
When you had it apart and during assembly, did you see and pay attention to the tiny hole on one side but missing on the other side of the gasket? (just throwing out ideas here) - Well many put it the wrong way. what gasket? They were all stuck to the carb, and I couldn't get them off. | |
| Who is online? | In total there are 23 users online :: 0 Registered, 0 Hidden and 23 Guests
