| | how good are peerless 930's? | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5372 Posts : 1311 Location : NW USA
![how good are peerless 930's? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | redlinemotorsportts Moderator
![how good are peerless 930's? Empty](https://2img.net/i/empty.gif) | Subject: Re: how good are peerless 930's? March 28th 2014, 11:36 am | |
| I have one, pretty generic... parts available.... doc has split a 920 in half so they all have their weaknesses. depends on how hard you romp them. remember they were just made for cutting grass. I think there right behind the mst and 801 style axles in strength | |
| ![Go down](https://2img.net/i/empty.gif) | | 1997 Murray Veteran Member
![how good are peerless 930's? Empty](https://2img.net/i/empty.gif) | Subject: Re: how good are peerless 930's? March 28th 2014, 12:52 pm | |
| all right, thanks for responding. don't you have one in the mtd? also, does anyone have any idea on what the high gear ratio is? | |
| ![Go down](https://2img.net/i/empty.gif) | | xxXMowerdudeXxx Established Member
![how good are peerless 930's? Empty](https://2img.net/i/empty.gif) | Subject: Re: how good are peerless 930's? March 28th 2014, 1:04 pm | |
| I've got one and been romping on it for a year had it going 45, no probs with it other then keeping gear oil in it, and the input bearings are going out from the high speedsXD | |
![how good are peerless 930's? Empty](https://2img.net/i/empty.gif) | Subject: Re: how good are peerless 930's? March 28th 2014, 1:07 pm | |
| Yes mines in my mtd. It doesnt get beat to hard because i need to re do my clutch, but its lasted good, makes a small wining noise. The ends of the case thats hug the axles are worn out too.... i just keep on running it | |
![how good are peerless 930's? Empty](https://2img.net/i/empty.gif) | Subject: Re: how good are peerless 930's? March 28th 2014, 1:19 pm | |
| thanks for replying, I was wondering about the berings because the ones on the imput on the jd's wear out for some reason. | |
| ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![how good are peerless 930's? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Guest Guest
![how good are peerless 930's? Empty](https://2img.net/i/empty.gif) | Subject: Re: how good are peerless 930's? June 12th 2014, 4:15 am | |
| - 1997 Murray wrote:
- how good are the peerless 930 trannys? I'm thinking about offering this guy $80 for the opposed twin and the tranny. http://bellingham.craigslist.org/grd/4362048224.html
The Peerless 920 and 930 are a BIGGER unit in size and as such, could require some subtle changes in drive belt size/length, idler pulley, brackets, linkages and etc. Well you just have to choose which of which fits to your beast, they are good! |
![how good are peerless 930's? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | how good are peerless 930's? | |
| Who is online? | In total there are 28 users online :: 0 Registered, 0 Hidden and 28 Guests
