 Military engines!
Moose
7 posters
Moose
Moose
Military engines! Empty
PostSubject: Military engines!   Military engines! Icon_minitimeFebruary 2nd 2014, 11:42 pm
So I found these a long time ago and forgot about them then after looking through my bookmarks found them again! You guys might like them since its pretty much a 15+hp engine for 400$ I have seen airboats and all sorts of tractors with them lodged in their engine bays Id get one but I have other plans... The are 32ci 4cyl opposed engines rated at 10hp by the government but actual hp is more like 15-20+ I have heard of people using tecumseh carbs and all sorts of modifications but they sound like drag engines if you pipe them right lol there are also 16 ci 2 cylinders and theres some 84ci 4 cyls if you can find them will post links
http://saturnsurplus.com/
http://store.colemans.com/cart/32-cid-engine-4-cylinder-unused-p-120.html
Military engines! 2447
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 3rd 2014, 10:06 am
Interesting... I think I'll look up Teledyne specs and see what that 4 cyl really is. These are basically generator motors, so the torque specs will be much higher than you would expect for the HP rating.
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 3rd 2014, 10:22 am
I've been around these some. They are derated by the military, figure double hp at least.
Carburetor floats in these get fuel logged. Maybe due to newer ethanol gas.
Pull start. Couple of 24v starter ones, not common. Can adapt a mazda starter to work, but I haven't done it.
Used in pumps, generators, and mules(small military truck).
Fairly light weight. 110lbs.
Saturn surplus is a great place to deal with.
Colemans is also a good place.
camomanusa
camomanusa
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 3rd 2014, 10:57 am
thats cool, i wonder how they would do in a tractor
Moose
Moose
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 3rd 2014, 11:31 am
Maybe I'll build a 4x4 mower someday and use it :p
T-Dub13
T-Dub13
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 3rd 2014, 11:54 am
That 4cyl boxer motor would be perfect for red fox!  Cool
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 3rd 2014, 1:39 pm
Exactly my thunkin. Shoot, I may put one in the Mitsu after it hit's a million miles lol
The torque specs on these motors are pretty impressive. Remove the governer, add a bigger carb, abd you have a decent driveable engine. US mil ratings are half of 80% max. That means the flat 4 rated at 20 hp is actually more like 50 as it sits. A vw carb and governer removed should bring it easily up to 65 or so.
(My info on mil ratings is from the late 80's, so any of you newer Mil members may have updated specs... if so, please chime in)
Moose
Moose
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 3rd 2014, 1:57 pm
saturn sells a keyed adapter for the flywheel you just bolt up to it so you can use it with pumps or pullies I saw a cub that had one stuffed in it
http://www.xtrememotorworks.com/Cub%20Cadet%20982T.htm
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 3rd 2014, 9:23 pm
Whats finding parts for these brutes like?
Moose
Moose
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 4th 2014, 2:21 am
parts are cheap and readily available Saturn surplus sells every part for them
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 4th 2014, 11:03 am
I see. Cool.
Now I need to find an extra $500 and get one...
Moose
Moose
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 4th 2014, 11:09 am
TheBeal wrote:
I see. Cool.
I have seen them for 150 before no idea why I didnt get them but colemans is your best bet if you dont wanna look around for 400$ I think they are well worth the money!
PostSubject: Military engines!   Military engines! Icon_minitimeFebruary 4th 2014, 12:35 pm
I saw a sears with a wisconsin v-4 in it, that would be a perfect replacement for one of those.
Moose
Moose
PostSubject: Re: Military engines!   Military engines! Icon_minitimeFebruary 7th 2014, 12:12 am
found another little beauty while being bored online today
http://www.easternsurplus.net/625.html
think it is around 13hp and looks pretty b/a
Military engines!
» Project: M&M's "military Mud Mowing Murray"
» Acquiring engines
» can i swap engines?
» Engines problem
» Look at these engines tecumseh and B&S
