 HOW TO: Airtank Forge
camomanusa
9 posters
HOW TO: Airtank Forge Empty
PostSubject: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 19th 2014, 1:52 pm
We are gonna builld a usefull size, fuel efficient forge, that is small enough to take along with you to where you need it. We are gonna do this with the stuff I can scrounge from my stash of junk. This puppy will get the steel hot enough to forge weld.<br><br>Ok, this is the victim, an old air tank that dont hold air anymore. 'Round here, there are one or two of these in 'bout every garage, carport, and toolshed. Brand new they are like $24 from Harbor Freight.
HOW TO: Airtank Forge Airtankforge001
First we mark for the cut. I had a chunk of steel exactly 6 inches high, so I set it beside it and marked along the sides, and the ends...
HOW TO: Airtank Forge Airtankforge002
HOW TO: Airtank Forge Airtankforge003
HOW TO: Airtank Forge Airtankforge005
HOW TO: Airtank Forge Airtankforge006
HOW TO: Airtank Forge Airtankforge007
This is the dangerous part, cutting out the line. I'm using a cutoff blade on my angle grinder. you can use a jigsaw, cutting torch, anything that will cut it will do. If you are using the tool that I am, keep in mind that you don't want to plunge too deep... just enough to cut through. if you get the thin disk bound up, BAD things happen!
HOW TO: Airtank Forge Airtankforge008
I'm gonna assume you do not have a welder. I normally, after making the cut down the first side, weld the hinges on, then continue the cut. I'm gonna do this the hard way, just for y'all, with nuts and bolts. Continue the cut on around till you get the top off.
HOW TO: Airtank Forge Airtankforge009
Use your file, sandpaper, or flap disc to dress the edges... them's YOUR fingers after all...
HOW TO: Airtank Forge Airtankforge010
Almost everyone has a set of door hinges stashed somewhere in a junk drawer
HOW TO: Airtank Forge Airtankforge012
Now put the top back on and trace where they go with your Sharpie
HOW TO: Airtank Forge Airtankforge013
HOW TO: Airtank Forge Airtankforge014
Drill the holes for the hinge bolts.
HOW TO: Airtank Forge Airtankforge018
HOW TO: Airtank Forge Airtankforge019
Now set the bottom half on end.
HOW TO: Airtank Forge Airtankforge032
Make several cuts (like an asterisk) centered 2 inches up from the bottom.
HOW TO: Airtank Forge Airtankforge033
Use a hammer to drive the wedges in.
HOW TO: Airtank Forge Airtankforge034
Drive in Your air pipe. I chose 1 1/2 in black iron pipe.
HOW TO: Airtank Forge Airtankforge035
Here's the hole
HOW TO: Airtank Forge Airtankforge036
Now do the same thing for the other end.
the pipe should slide all the way through.
HOW TO: Airtank Forge Airtankforge039
HOW TO: Airtank Forge Airtankforge038
You want to be able to open both ends so that you can remove the ash that builds up in it. Most people use a screw on cap and a threaded pipe, I just made a slip in plug from another piece of pipe that already had an end on it.
HOW TO: Airtank Forge Airtankforge044
HOW TO: Airtank Forge Airtankforge045
HOW TO: Airtank Forge Airtankforge046
Decide which end is gonna be the front, and make two cuts like so... using your high tech bending tool, bend the piece down to make a shelf
HOW TO: Airtank Forge Airtankforge041
HOW TO: Airtank Forge Airtankforge042
Clean up your edges..
HOW TO: Airtank Forge Airtankforge043
You should now have something that resembles this
HOW TO: Airtank Forge Airtankforge047
HOW TO: Airtank Forge Airtankforge048
HOW TO: Airtank Forge Airtankforge049
Now drill a line of holes down the center of the pipe
HOW TO: Airtank Forge Airtankforge052
So here's where we start the day:
HOW TO: Airtank Forge 1airtankforge001
Now grab your shovels. Most peoples back yards have clay in them, if you dig a bit. Here, about a foot of topsoil covers that good 'ole Carolina Brickmakin' clay! If you don't have clay in your area, buy a bag of the cheapest clay kitty litter you can find, and soak it for a day in water... mix it in your backyard dirt. It works great.
HOW TO: Airtank Forge 1airtankforge003
Time to line the Forge!
Start packing the damp clay sand mix against the walls. Pack it as tight as you can. If your spouse thought something was wrong with you when you started this project, seeing a grown adult playing in the mud might make 'em call the "nice young men in the clean white coats" to pay you a visit!
HOW TO: Airtank Forge 1airtankforge004
HOW TO: Airtank Forge 1airtankforge005
This is something like what you should have at the end. I didn't bolt the lid on, so you could see what I'm doin better
HOW TO: Airtank Forge 1airtankforge006
I had this SS angle iron Base that I scavenged (Legally!) from work, looks like great forge table material to me! Add a metal door from an electrical cabinet and Viola! An all metal, non-flammable forge table!
HOW TO: Airtank Forge 1airtankforge007
Now most of y'all will use one of these to provide airflow. That Hairdryer provides PLENTY of air for a forge of this design.
HOW TO: Airtank Forge 1airtankforge010
Doh! I got Caught! Well, back to scrounging... I found this old squirrel cage blower in an exhaust fan from a bathroom I demo'd out on the base. It'll do!
HOW TO: Airtank Forge 1airtankforge011
Now we have the old Round Peg / Square Hole problem... Let's see... A quick raid of the pantry when the wife wasn't looking netted me a can of pumpkin (leftover from thanksgiving) that's just about the right size...
HOW TO: Airtank Forge 1airtankforge012
Empty the contents, and make four 90 degree bends to make one end square...
HOW TO: Airtank Forge 1airtankforge014
HOW TO: Airtank Forge 1airtankforge015
The bottom had a circle JUST the right size for the pipe... Cut it out, place square end in square hole, round pipe in round hole and You're there!
HOW TO: Airtank Forge 1airtankforge013
Fire that thing up!
HOW TO: Airtank Forge 1airtankforge020
HOW TO: Airtank Forge 1airtankforge019
With the lid on
HOW TO: Airtank Forge 1airtankforge021
Dang that air blast is high!
HOW TO: Airtank Forge 1airtankforge022
Normally I would place a dimmer switch in the circuit but... lemme try something here
HOW TO: Airtank Forge 1airtankforge023
Yup, it worked! Looks kinda homegrown though... Lemme see what else I've got..
HOW TO: Airtank Forge 1airtankforge024
Perfect! Add a screw to make it permanent, and I have an easily adjustable airflow!
HOW TO: Airtank Forge 1airtankforge028
HOW TO: Airtank Forge 1airtankforge027
HOW TO: Airtank Forge 1airtankforge026
This was a bit more serious build than the chevy rim forge, and it was intended for a more serious backyard smith. The advantage is this one has a lid, is easily portable (with the hairdryer airsource) will last for years, and is big enough to handle 16 inch blades. If you are working on smaller blades, you can cover up most of the holes with mud and save charcoal. Most of this is based on Tim Lively's design (Tim's a great fellow, you really should check out his site), and adapted to what I had laying around.
I purposefully used basic tools, to show you that it can be done by just about anyone. Hope you enjoyed, and happy Forging!
This forge is big enough to bend linkage rods, straighten bent rods and make leaf springs from lawnmower blades. Charcoal is cheaper than oxy acetalene
Last edited by Lawren Wimberly on January 19th 2014, 2:52 pm; edited 1 time in total
camomanusa
camomanusa
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 19th 2014, 2:20 pm
i dont think thts right Razz
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 19th 2014, 2:59 pm
it took an hour to recode the images... hope y'all like it
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 19th 2014, 3:09 pm
Nice work LW!
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 19th 2014, 3:30 pm
this aint my first rodeo TRB (grin)
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 19th 2014, 3:52 pm
I've got one for a backyard metal smelting furnace too if y'all are interested... I'll also do a basic heat treating thread
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 19th 2014, 4:57 pm
Do it!
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 26th 2014, 8:53 pm
Not only is the forge cool, but the tute is excellent too. Thanks!
Moose
Moose
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 27th 2014, 10:25 am
great idea! Very Happy gonna try this out sometime please post the smelter too could really use one for brass casting and stuff!
T-Dub13
T-Dub13
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 27th 2014, 11:51 am
Nice Writeup LW!
Moose
Moose
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJanuary 27th 2014, 11:57 am
Id also like to note if you hook a piece of pipe to the vent hole in the top you could use it in a cold smoker if you throw a block of hickory in it Smile
Andy from Chenango Forks
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeJune 4th 2014, 1:24 am
Great write-up, thanks for sharing!
retired guy
PostSubject: Re: HOW TO: Airtank Forge   HOW TO: Airtank Forge Icon_minitimeNovember 19th 2018, 4:33 pm
Built this for my old shop. Scrounged it all.HOW TO: Airtank Forge 28059110
All-Terrain Lawn Tractor Forum :: New Member Forum :: How-to + FAQ-
