if I push my clutch in and my tractor keeps going do I need a bigger belt or do I need to adjust my clutch to release it even more I just pulley swapped it so im still getting it dialed in
Doc Sprocket Site VIP
You may need to adjust the fingers that make the belt pucker around the pulleys when the clutch is actuated. Without these, the belt will continue to ride on the pulleys and drag.
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5152 Posts : 1068 Location : New jersey
