 Hydro Mudder Goal is 17+ MPH
redzz02
TroyBilt Pony
crafsmankiller
MoWheeler
RCG
16 posters
RCG
RCG
2016 Build-Off Finalist
Hydro Mudder Goal is 17+ MPH Empty
PostSubject: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 9:25 am
As most of you know I Redneckcomputergeek hate when some one says you cant do it.  Having already set a high bar for my self with Maine Mud Mowers build (See build log here https://www.atltf.com/t1612-been-there-done-that ). I think its time to take a look at the much hated world of hydro's.  Now I'm not the first to want to mud a hydro and others have worked on making then faster with pulley swaps and seen mixed results to say the least.  But to my knowledge none of them have broken past 12mph let alone the 17 to 20 I hope to hit.  So well everyone else was sleeping I got to work.
Hydro Mudder Goal is 17+ MPH 2013-110
Hydro Mudder Goal is 17+ MPH 2013-112
Hydro Mudder Goal is 17+ MPH 2013-113
Hydro Mudder Goal is 17+ MPH 2013-114
They say a picture is worth a thousand words but I think video does it much better!
http://www.Mudmower.com
MoWheeler
MoWheeler
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 10:06 am
Wouldnt you want the sprockets to be the other way? The large one on the hydro and the small on the live axle? Because the way it is now it would be gear reduced even more and go slower?
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 10:10 am
MoWheeler is correct, the way it is now the gears would be reduced!
MoWheeler
MoWheeler
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 10:13 am
It would be slow but could pull a mountain if you got traction!
RCG
RCG
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 10:14 am
Ok so now the fact I messed up at the end is out of the way. What do you guys think will it work?
PostSubject: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 10:24 am
yes, this should work, we have a scotts hydro, and it is nice to drive, it would be great if it where faster, though. once I got a taste of speed, I wanted more lol.
MoWheeler
MoWheeler
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 10:26 am
I would say so. It should scoot pretty good as long as your engine can run the hyro pump.
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 10:33 am
I'm just wondering to see how much the big sprocket protrudes thru the fenders, and I think you have to cut the axle off the stock hydro.
crafsmankiller
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 11:06 am
in my experience hydros mud pretty good, but you cant have the clutch half way out and 'creep' with 'em
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 12:24 pm
looks like a solid plan to me, any plans on a oil cooler for the hydro? My prediction is that it will work, but the hydro unit will overheat, and possibly burn up due to it doing 3x the work that it was designed to do. if you can get a cooler/ bigger reservoir to bump up the oil capacity on the hydro it would help the longevity alot. my 2 cents
MoWheeler
MoWheeler
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 1:32 pm
Yep! ^^^^ Nothing worse than geting your preject done and riding it for a short time only to break it. Believe me... I would know.
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 1:38 pm
on that note, I have a hydro gear 310-510 hydrostatic trans, it will be easy to put a oil cooler on it but I would need a external pump and auto trans cooler off a truck with hose and I need to drill and tap a fitting off the lowest point of the tranny.
I can push about 12mph on it but I cant pull any thing at that speed or at all. try pulling a 14'x8' 800lbs trailer with 12 40-50lbs bales and a person on it, I will go up a hill but the 10cc pump in the trans isn't powerfull enough with a 22.2:1 ratio.
PostSubject: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 1:58 pm
yeah, our scotts hydro stopped working after my dad used it to drag logs up a 100 foot incline (it is so steep that a mower would flip over if you tryed to drive it down there) I had to finish the job with the MTD Hydro Mudder Goal is 17+ MPH Icon_razz(after an hour the belts where dead) then the Murray in its former self filled in until its tiers went flat and ITS belt was bunt. (it wasn't long.)Hydro Mudder Goal is 17+ MPH Icon_evil
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 4:36 pm
So what sets the restrictions in a hydro? Is it the motor's cc?
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 4:49 pm
Internal gearing i think
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 12th 2013, 4:52 pm
also if you have room under the hood??? Try a tranny cooler and e fan Very Happy stock alternator should do okay with the fan.. or put it on a switch when going over 8-10 flip it on..
RCG
RCG
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 15th 2013, 8:32 pm
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 15th 2013, 8:45 pm
I'm watching this one closely to see how it turns out. The theory is pretty sound, indeed. But I'm wondering about side effects. I think with the overdrive, you'd lose a lot of the natural braking a hydro usually offers. I'm also quite interested to see (and it's be better to FEEL it) what it drives like, overall. Will coasting be effect, or even possible? Will it hold up to the strain and possibly heat?
All in all, many of us have thought of or suggested the concept. Hat's off to you for taking the plunge and actually putting it into motion... Literally!
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 15th 2013, 8:58 pm
I would put a pillow block in the middle of the frame for some, not a lot, of strength to that axle.
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 15th 2013, 9:19 pm
Honestly, I'm not sure that's necessary. Normally, I'd agree. But he's got the drive sprockets located close to the frame points, and the wheel hubs aren't far off that. There isn't much stress on the central part of the axleshaft.
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 15th 2013, 11:29 pm
but there is, where is it going to bend first? at the frame or in the middle of the axle? naturally it will want to bend in half, if you ut a bearing in the center of it its going to take alot more of leverage to bend the axle at the frame with about 6 inches of leverage opposed to the whole width of the axle
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 16th 2013, 6:41 am
Well- it's going to want to bend where the forces concentrate- at a leverage point. Generally, just outboard of the frame mounting point (bearing). Ask a guy that has snapped an axle (LOL).
If it were a go kart, or some other arrangement where the drive sprocket were located in the middle of a lot of unsupported axle, I would call it paramount.
But like anything else untried, this will reveal itself.
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 16th 2013, 8:02 am
Mechanically, I'd say it's a sound idea. Since the hydro is not being overspeed on the input, it should not overheat. If you use the hydro to set your gearing, then use the throttle as a gas pedal, it shouldn't see a lot of strain. Driving, I'm not sure how it will run, be interesting to find out. Just don't slam the hydro control on and off, or fwd to reverse.
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 16th 2013, 8:08 am
I think it's a solid idea, and finally somebody is doing it.
I know on karts they just add a "doubler" in the center of a long axle, Axle Stiffener but that don't take the strain on long thin axles from the bearing to the wheel hubs, so i would build a = brace in time.
And ofcourse 17mph won't be a problem now, since you do the gearing after the hydro tranny, clever.  cheers
PostSubject: Re: Hydro Mudder Goal is 17+ MPH   Hydro Mudder Goal is 17+ MPH Icon_minitimeDecember 16th 2013, 8:25 am
All i see is that if you put more blocks as close as possible to the rims then theres no need for a center support. hydros can pull a good abount so upping the gearing souldnt hurt it that much. I think going from max speed to stop (decending speed) will be intrusting.
» Murray Monster Mudder
» Got the tranny out of the cub
» Hydro - do or do not?
» Do you love or hate hydro's?
» Simplicity 4208 Mud Mower Project
