| Hydro Mudder Goal is 17+ MPH | |
+12Stretch44875 redzz02 Doc Sprocket TroyBilt Pony Thunderdivine Creepycrawler crafsmankiller redlinemotorsportts 1997 Murray Ariens YT11 MoWheeler RCG 16 posters |
| Subject: Re: Hydro Mudder Goal is 17+ MPH December 16th 2013, 8:25 am | |
| All i see is that if you put more blocks as close as possible to the rims then theres no need for a center support. hydros can pull a good abount so upping the gearing souldnt hurt it that much. I think going from max speed to stop (decending speed) will be intrusting. | |
crafsmankiller Member
Age : 27 Join date : 2012-10-18 Points : 4895 Posts : 412 Location : livingston texas
| Subject: Re: Hydro Mudder Goal is 17+ MPH December 16th 2013, 11:35 am | |
| - Stretch44875 wrote:
- Just don't slam the hydro control on and off, or fwd to reverse.
well thats no fun..... | |
RCG Member
2016 Build-Off Finalist
| Subject: Re: Hydro Mudder Goal is 17+ MPH December 16th 2013, 12:50 pm | |
- I think going from max speed to stop (decending speed) will be intrusting.
Agreed this is when the gear ratio will not be in my favor | |
RCG Member
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5448 Posts : 1311 Location : NW USA
| Subject: Hydro Mudder Goal is 17+ MPH December 26th 2013, 5:15 pm | |
| try sliding the axle as far forward as you can, take a link out, then pull the axle back as far as you can. good job so far!
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5703 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Hydro Mudder Goal is 17+ MPH December 26th 2013, 7:40 pm | |
| Could use a half link. Do you have any adjustment built into the rear axle to tighten chain?
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7320 Posts : 2914 Location : Ontario Canada
RCG Member
| Subject: Re: Hydro Mudder Goal is 17+ MPH December 26th 2013, 8:18 pm | |
| yes the pillow blocks have slide holes about 1/2 inch of play. I went back after the video and relized I had drilled the holes on one side a 1/4 off to the front. I redrilled and remounted them. Going to need an idler pulley latter but for testing it out this will work.
RCG Member
T-Dub13 Established Member
Age : 55 Join date : 2013-12-06 Points : 4574 Posts : 540 Location : Central MA
| Subject: Re: Hydro Mudder Goal is 17+ MPH January 13th 2014, 12:53 pm | |
| This is a great build. A long overdue experiment as well. Seems to me that it should work. I don't think there's a better way really. The multiplied load on the output of the hydro may create more heat. The hydro will be working harder (like going uphill in both directions). Maybe doubling up on the fan to make it more efficient and adding a cold air intake duct would help if needed. the chain is going to stretch anyway, so just test it and keep an eye on it. Moving the pillow blocks in slots will work, but the pull from the chain may yank the axle back to the loose position. I think I'd stack washers or spacer plates under the pillow blocks to adjust the chain. That way you could keep the bolt holes instead of slots. Just thinking out loud here. Love the build! | |
Age : 57 Join date : 2013-12-21 Points : 4807 Posts : 744 Location : Salem Illinois
RCG Member
| Subject: Re: Hydro Mudder Goal is 17+ MPH January 13th 2014, 4:04 pm | |
| Sorry guys Blowing the trans in Maine Mud Mower set me back this weekend. Now that the wiring is done I can get back to putting the sheet metal back on then its time for a test drive. | |
| Subject: Hydro Mudder Goal is 17+ MPH January 13th 2014, 4:18 pm | |
| get an 820! by the way, where do yo guys get your trannys? sorry to hear about your tranny , do you have a video? | |
RCG Member
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4421 Posts : 491 Location : Index, Washington
B440 Member
Join date : 2014-01-22 Points : 4206 Posts : 226 Location : Thompson, CT
| Subject: Re: Hydro Mudder Goal is 17+ MPH August 2nd 2014, 10:41 pm | |
| I suspect he lost too much torque for hills and mud, going from such a large sprocket to a small one. Definitely not a good application if you're trying to conquer a hill | |
