| need help wiring a 14 hp briggs to a old 70s dynamark | |
montemuscle7779 New Member
Age : 37 Join date : 2013-11-14 Points : 4029 Posts : 4 Location : VA
| Subject: need help wiring a 14 hp briggs to a old 70s dynamark November 14th 2013, 3:33 pm | |
| currently working on a old dynamark and did a engine swap from the old 11hp briggs to a 14hp briggs I/C the engine swaped nicely and bolted in great, but now I have to wire it up and need a lil advice. the new engine has the a carb solinod and i cant figure out where to run it, also the old wiring has a fuse inline from the battery to the key switch and when the fuse is in it drains the battery, so can i do away with that? would it be easer to put a push botton in. any help would be great thanks. | |
| | | k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5365 Posts : 1135 Location : Southern Florida
| Subject: Re: need help wiring a 14 hp briggs to a old 70s dynamark November 14th 2013, 3:47 pm | |
| For the electric fuel Shutoff thing I usually just put a solid bolt in it they are always a pain abs sounds like your key is bad drawing like that cause whenever I leave my key on it kills the battery | |
| | | Doc Sprocket Site VIP
| Subject: Re: need help wiring a 14 hp briggs to a old 70s dynamark November 14th 2013, 6:19 pm | |
| With regards to the anti-afterfire solenoid, most of us simply clip the end of the needle off and reinstall (without wiring) or replace it altogether with a short bolt. These things can be problematic, and do nothing for you except justify a paycheck in some EPA office.
The battery draining issue may be a bad diode in the alternator wiring harness, or a wiring fault. | |
| Subject: Re: need help wiring a 14 hp briggs to a old 70s dynamark November 14th 2013, 6:26 pm | |
| - Doc Sprocket wrote:
- With regards to the anti-afterfire solenoid, most of us simply clip the end of the needle off and reinstall (without wiring) or replace it altogether with a short bolt. These things can be problematic, and do nothing for you except justify a paycheck in some EPA office.
The battery draining issue may be a bad diode in the alternator wiring harness, or a wiring fault. i like that idea thanks for the tips guys | |
| Who is online? | In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests
