| upgraded brakes? | |
murrayracer Member
Age : 27 Join date : 2013-07-14 Points : 4258 Posts : 84 Location : Benton city, WA
| | | | murrayracer Member
| | | | MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4752 Posts : 477 Location : Haddock,Georgia
| Subject: Re: upgraded brakes? November 8th 2013, 5:19 am | |
| you can get a cheap 6" brake disc with a 3/4" bore as well as a mechanical break caliper i cant remember where i seen it at haha having some bad brainfarts but im sure most mower have enough room between the frame and tire to mount one | |
| | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7321 Posts : 2914 Location : Ontario Canada
| Subject: Re: upgraded brakes? November 8th 2013, 6:08 am | |
| I wouldn't be too quick to trust my butt to bicycle brakes. Try looking for go kart brakes. A good mechanical system can stop you efficiently and reliably. | |
| | | Speedfreek241 Member
Age : 26 Join date : 2013-07-12 Points : 4332 Posts : 137 Location : Loxahatchee
| Subject: Re: upgraded brakes? November 8th 2013, 6:23 am | |
| You can do this and they will lock up the back tires but they wear out fast. | |
Age : 28 Join date : 2013-04-10 Points : 5764 Posts : 1408 Location : Galway NY
| Subject: Re: upgraded brakes? November 8th 2013, 9:00 am | |
| i just put my feed down, i keep my olde workboots and use them. i have seen people also make a piece of rubber that gets rammed against the rear tire when you push a lever... LOL, in all seriousness, i wouldnt trust bicycle brakes either. try to find a good kart brake and disc, hell, even an ATV hydraulic brake if you want to go that route | |
| | | murrayracer Member
| | | | k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5374 Posts : 1135 Location : Southern Florida
| | | | murrayracer Member
| Subject: Re: upgraded brakes? November 8th 2013, 5:49 pm | |
| It is the same disk and caliper that they use on some bikes though. I know because me and k2500life built this on my transaxle but put it in his mower. | |
| Who is online? | In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests
