Sorta put my mod projects aside for now- id like to get my mowing tractor projects finished- put em off way too long now.
85 craftsman LT11- deck needs rebuilding, motor and wiring put on - also nephew cut the deck engagement lever- need to sort that out also - will get new silver paint next year
85 craftsman LT12 - need to build a whole new deck, pullies/belt sorted out ( clutch dosent work) - trans is also sticking a bit as well - getting some blue neon lights as well
95 MTD lowes machine - rewire, rebuild deck - just doing a running resto for now
99 hydro murray- carb rebuild and set up new deck for it ( old pic too)
The 70 toro will wait a bit longer- that needs some sorting out to be returned to mowing duty
Mod projects:
wizard- go kart setup with 5HP honda/go kart clutch, lowered, running 6" rims- might end up with the 20HP onan ( if i can get running)
96 MTD 3 speed 'varidrive" - needs motor, might need to change clutch setup
91 mod MTD - waiting for 18.5HP twin transplant, stacked pulley built - might upgrade to 6 speed 'shift on the go' trans out of 94 murray eventually
94 murray rebuild - will get 14.5HP motor, different clutch setup, front axle lowering , lower profile rear wheels
agway - decided keeping as an offroader - will get 11HP briggs or 12HP teccy to abuse- if i get ags for back tires- the back tires will go on front- gas pedal setup.
wheelhorse mod - put off for later date
IF i can get that scooter carb setup on the spare 18HP twin- that motor will go on the 91 MTD mod- and the 18.5 will go on the 88 kleen kut to get that mowing again - which has sat engine less for about a year now.
