 Poulan utility tractor build.
Moose
T-Dub13
Craftsman1998
17 posters
Poulan utility tractor build. - Page 3 Empty
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeFri Feb 07, 2014 7:17 pm
The problem with high altitude is it makes the mixture run RICH. More fuel than air is available. I think you are going the wrong direction on your jet sizes... for high altitude, you need to lean the mixture. That has been y experience, anyway... after moving from Fla to the mountains of MT, I had to re jet my VW bug 'cause it kept flooding.
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeFri Feb 07, 2014 8:41 pm
well guys I may did something wrong, I drilled out the main jet to 1/16" and Lawren I thinn you got it backwards, I talked with the guy at school said that at higher elevation you need bigger jets, I'm thining about a fuel pressure system on my tractor soon. wait my V-twin has a fuel pressure system, Damn when is that starter gonna show up?
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeFri Feb 07, 2014 8:56 pm
T-Dub13 wrote:
I'd suggest going the largest size before you start cutting brass.  (Cleaning out all the gunk).  Then going one sixe larger.  You might want to pickup a set of number drills (60-80).  If you're going to work on carbs, you're going to use them a lot!
DRILL SET
Poulan utility tractor build. - Page 3 41uLkgPwEaL._SX425_
Precisely. Start with a clean jet, and use the shanks of your numbered bits to figure out what size you currently have. ONLY work one size at a time. Screw it up, and you're soldering the jet closed and doing it again. Ask me how I know... LOL
AND- Lawren is correct. Lean it out for higher altitude. The air is LESS dense- thinner, less oxygen. Therefore, your current, low-altitude jetting is too rich.
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeFri Feb 07, 2014 10:42 pm
well I know the jet originally is a 118 atleast what it has numberd on it, I'm running 85 octain fuel here in Wy, not 90 92 96 98 octain fuels. I know it is running lean, because is not smoking when using chocke on startup or when running, maby its time for a smog pump supercharger... Very Happy
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 08, 2014 1:56 pm
well it runs, only thing I need now is a smog pump.
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 08, 2014 2:12 pm
hit the junk yards brother
Moose
Moose
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 08, 2014 2:17 pm
seems like lawren would be right though because you have limited o2 at higher altitude youd need to tone the fuel down the slightest bit or youd be running to wet and have unburnt fuel I dunno lol Im just a engineer not a mechanic
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeThu Feb 13, 2014 9:31 pm
Well it was running lean before the jet was drilled, I asked someone at school, it is slighly running too rich at the moment, I am gonna be getting a starter for the twin soon. then mount the twin to the chassis and take it to school so they can tune the carb on it.
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeFri Feb 14, 2014 7:53 pm
Poulan utility tractor build. - Page 3 1662231_506237616164076_1723973054_n
Craftsman1998
Craftsman1998
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeFri Feb 14, 2014 7:56 pm
I can still see some paint romp harder lol
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeFri Feb 14, 2014 8:02 pm
that is the best I could do since the motor needs fine tuning yet
Craftsman1998
Craftsman1998
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeFri Feb 14, 2014 8:51 pm
Lol i was just messing with you. You should make a video of how its running now.
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeThu Feb 20, 2014 8:36 pm
Well all my starter for the twin will be at my door around the end of the month or first of march, gonna swap the twin in the next day or so then use it. Smile
Craftsman1998
Craftsman1998
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeFri Feb 21, 2014 9:10 am
Awesome Very Happy
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 22, 2014 12:51 pm
Time to Work!!!!
Poulan utility tractor build. - Page 3 1656114_510443315743506_1045095834_n
Poulan utility tractor build. - Page 3 1891192_510444775743360_943383506_n
Poulan utility tractor build. - Page 3 1800198_510445185743319_1023887332_n
Poulan utility tractor build. - Page 3 1800339_510445572409947_1480839466_n
Poulan utility tractor build. - Page 3 1800339_510446425743195_1166277059_n
Craftsman1998
Craftsman1998
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 22, 2014 1:01 pm
Looking good
camomanusa
camomanusa
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 22, 2014 1:19 pm
its getting there  cheers
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 22, 2014 1:26 pm
I got it running again!!!
I am having to pull start it off the bolts for the flywheel shoud.
I am just running straight pipe ATM and gonna be putting my side pipe on it.
Getting Starter From "EDI" around the first of the month so I can use the Key to start it.
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 22, 2014 2:13 pm
I aint never lendin YOU my mower, ya got it all muddy!
Poulan utility tractor build. - Page 3 1222323911
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 22, 2014 3:50 pm
LOL isn't getting our mowers dirty the reason we are here?
LOL
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 22, 2014 5:45 pm
not me... I don't wanna get my rust dirty
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 22, 2014 6:17 pm
OOOHHHH LOL
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Feb 22, 2014 8:16 pm
ok i headed out tonight and i tried to start the twin, fired right up, now I need t fill the tank up on it and see how long 2gal lasts.
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeThu Feb 27, 2014 8:41 pm
I got my side pipe mounted and it sounds beastly! its tucked under the foot board in front of the rear tire.
i was reving it up and flames came out of the exhaust like 4" out of the pipe!
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeSat Mar 15, 2014 3:33 pm
ok, Well I have a Q: is this thread not interesting or is it something else? and I got a starter on the way, will be doing a unboxing vid and much more is coming since summer is on its way!
PostSubject: Re: Poulan utility tractor build.   Poulan utility tractor build. - Page 3 Icon_minitimeFri Mar 28, 2014 11:13 pm
OK as of right now I am anouncing that tomarrow I am gonna be doing a huge update and hopeully gonna get it posted tomarow night, 2 parter maby more.
» huskee trail/utility tractor build
» Poulan garden tractor on/off road build
» Utility tractor build
» 74 sears utility tractor build
» New guy, first Off Road/ Utility tractor build.
