| Poulan utility tractor build. | |
+13Moose T-Dub13 Craftsman1998 Lawren Wimberly richie thomas 1997 Murray TheRainbowBoxer redlinemotorsportts Stretch44875 Doug Doc Sprocket willis923 k2500life 17 posters |
richie thomas Veteran Member
| Subject: Re: Poulan utility tractor build. December 13th 2013, 6:29 am | |
| - Ariens YT11 wrote:
- its gonna get srapped unless someone makes a deal on a chasis with bad tranny.
come on now, just keep it and work on other stuff while lookin for a tranny | |
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5449 Posts : 1311 Location : NW USA
Age : 27 Join date : 2012-10-31 Points : 5167 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Poulan Rally machine December 13th 2013, 1:02 pm | |
| couldn't you just replace it? or do you just want a better tranny? say, how did you get this poulan? it looks pretty new. | |
| Subject: Re: Poulan utility tractor build. December 13th 2013, 7:18 pm | |
| I got it from my grandma, it is a 2006 model and I have had it since 2008. Lots of acres of land have been mowed with this mower.I can easily bet up to 1500-2000 acres. | |
| Subject: Poulan Rally machine December 16th 2013, 1:15 pm | |
| I lost my grandma to cancer to, but she had moved from her farm to a house in town by then, so she didn't have a mower. | |
| Subject: Re: Poulan utility tractor build. January 2nd 2014, 2:25 pm | |
| Well here is a update on the Poulan.
Peerless 801, Suspention on rear, 16Hp v-twin, "new" front tires, and some fenders for the front and back tires
Age : 57 Join date : 2013-12-21 Points : 4808 Posts : 744 Location : Salem Illinois
| Subject: Re: Poulan utility tractor build. January 2nd 2014, 3:21 pm | |
| I will get pictures soon, In the wrong area and camera is at the house and I am almost 30min away. | |
| Subject: Poulan Rally machine January 2nd 2014, 3:22 pm | |
- Well here is a update on the Poulan.
why do you want a 801? get a 820 | |
| Subject: Poulan Rally machine January 3rd 2014, 10:48 am | |
| oh, I was under the impression that you where going to buy one. | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5155 Posts : 1068 Location : New jersey
| Subject: Re: Poulan utility tractor build. January 22nd 2014, 8:58 pm | |
| Sorry I didn't get photos, I found out the 5 speed is a 844 peerless, and for now I'm just doing maintenance to the hydro, 20w-50 motor oil is what is required for the oil | |
T-Dub13 Established Member
Age : 55 Join date : 2013-12-06 Points : 4575 Posts : 540 Location : Central MA
| Subject: Re: Poulan utility tractor build. February 4th 2014, 1:46 pm | |
| Fuel starvation. Check fuel flow from the fuel tank all the way to the bowl. With the bowl removed, fuel should pour out. I have a feeling it won't. So chase the problem upstream until you find the beaver dam. Also, make sure your fuel cap is vented. Good luck! | |
| Subject: Re: Poulan utility tractor build. February 4th 2014, 4:50 pm | |
| MMMMM.... a common problem with some of the newer machines is the fuel cap has a rubber bladder/diaphram on the bottom... similar to what you would find in a master cylinder. I have a TBP in the yard right now with less than 5 hours run time (but it sat for 5 years) and the diaphragm has deteriorated to small pieces that clogged the whole fuel system. Had to remove all the hoses, clean the carb, empty and blow out the tank. I replaced the diaphram with a paper (cardboard) disk. | |
| Subject: Re: Poulan utility tractor build. February 7th 2014, 11:49 am | |
| I know the fuel getting to the carb is fine, I had someone at the school I go to clean it out, I need to drill out my main jet, any drill bit size recomended for that being 4,500 ft up? | |
| Subject: Re: Poulan utility tractor build. February 7th 2014, 7:16 pm | |
| I'd suggest going the largest size before you start cutting brass. (Cleaning out all the gunk). Then going one sixe larger. You might want to pickup a set of number drills (60-80). If you're going to work on carbs, you're going to use them a lot! DRILL SET | |
| Subject: Re: Poulan utility tractor build. February 7th 2014, 8:17 pm | |
| The problem with high altitude is it makes the mixture run RICH. More fuel than air is available. I think you are going the wrong direction on your jet sizes... for high altitude, you need to lean the mixture. That has been y experience, anyway... after moving from Fla to the mountains of MT, I had to re jet my VW bug 'cause it kept flooding. | |
