 huskee trail/utility tractor build
DiezelFuel
DiezelFuel
huskee trail/utility tractor build  Empty
PostSubject: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 6th 2017, 11:37 pm
I've been wrenching on this tractor the last couple days, I got it on trade it wasn't running. I got it running after a few hours of trouble shooting I figured out it was just a bad ground from the battery to the frame. huskee trail/utility tractor build  1098998679 lol I cut the shaft off the original pulley and welded it on the opposite side. It was the perfect length. I then dropped the transaxle and got the original pulley removed, snagged a donor transaxle from my garage with a slightly smaller diameter pulley. I will pull that pulley in the morning and have it running tomorrow evening if all goes smoothly. It has the same diameter front axle as my smaller custom craftsman's spare wheels so I will be extending those spindles to mount those when I get some bigger rear tires I'm thinking something the size of case 446 rears It does have larger axles and a bigger transaxle I didn't check the model yet but I'm hoping to get 15-25mph maximum. huskee trail/utility tractor build  2240318088
huskee trail/utility tractor build  Kimg0912
huskee trail/utility tractor build  Kimg0910
huskee trail/utility tractor build  Kimg0913
huskee trail/utility tractor build  Kimg0911
huskee trail/utility tractor build  Kimg0917
huskee trail/utility tractor build  Kimg0921
huskee trail/utility tractor build  Kimg0919
huskee trail/utility tractor build  Kimg0916
huskee trail/utility tractor build  Kimg0920
huskee trail/utility tractor build  Kimg0924
huskee trail/utility tractor build  Kimg0922
huskee trail/utility tractor build  Kimg0915
huskee trail/utility tractor build  Kimg0914
huskee trail/utility tractor build  Kimg0923
huskee trail/utility tractor build  Kimg0926
huskee trail/utility tractor build  Kimg0925
huskee trail/utility tractor build  Kimg0918
huskee trail/utility tractor build  Kimg0927
huskee trail/utility tractor build  Kimg0929
huskee trail/utility tractor build  Kimg0928
Here is a video of it running it only has maybe 6 inch pipes coming out so its obnoxiously loud but I'm thinking two stacks will quiet it down a bit in the near future. huskee trail/utility tractor build  2664539216
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 7th 2017, 12:08 am
That first transaxle looks like a Peerless 820. 1" axle shafts, nice! Hahaha. Case 400 series rear tires are about 31" I think, should look cool!
sadeoo7
sadeoo7
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 7th 2017, 12:52 am
how did you get a 820 !!! cant find one for the life of me ! should be bulletproof.
what else are you planning ? gas pedal ? bumpers ?
http://gdftech.com
DiezelFuel
DiezelFuel
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 7th 2017, 9:58 am
Its the transaxle that came on the tractor huskee trail/utility tractor build  2240318088  haha I'm hoping they will look cool but I might have to widen the rear end so I'm not using the tires for arm rests. haha I've been doing some tire research I'm wondering how hard it would be to find rubber to fit the stock rims or would it be easier just to find some and figure out a hub? scratch  lol  I'm definitely doing a gas pedal and some bumpers. I will be hitting the scrap yard a couple times this week they always have good square steel tube and such. Get some offroad lights like AllisKidD21 has and maybe throw a winch on it. I will probably leave the steering for now it seems pretty solid. I would love to fab a 2 or 3 point hitch and use linear actuator(s) like this one. https://www.amazon.com/dp/B00X09LOOO?psc=1  I think that will have to wait a couple weeks though that actuator isn't cheap. I think that's about all I got in mind so far but I'm sure I will come up with more. huskee trail/utility tractor build  1098998679
DiezelFuel
DiezelFuel
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 7th 2017, 11:28 am
I got the transaxle back in with the new pulley, I think I need to do a dual pulley clutch like I've seen a lot of you guys use. Should I lock the transaxle? Would docs weldless locker work in it? scratch haha I don't know if it would be ideal though considering I want to use it as a utility tractor especially if I get the 3 point figured out. Oh and what do ya'll think is the best replacement fluid for the transaxle? I know its a lot of questions but I want to treat this transaxle right haha
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 7th 2017, 11:34 am
From what I understand the ring gear setup is differenet in a 820 series than an MST or 930/920, so the Doc Locker 2.0 wont work. But Doc did recently come up with the Doc Locker 820 for the trans in Fugazi. He has a video on it I'm pretty sure.
Also 80w/90 gear oil should be fine for a transaxle.
sadeoo7
sadeoo7
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 7th 2017, 2:38 pm
to lock your 820 i would fozzy lock ot or doc lock it !
https://www.youtube.com/watch?v=bq0QoEjg2yk
for lube i use gear oil, doc used 15w40 diesel oil, i like the gear oil because its thicker so it tends to leak alittle less.. but if it gets really cold in the winter its a little stiff to shift until it warms up..
Cool Build ! Keep us updated !
http://gdftech.com
DiezelFuel
DiezelFuel
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 7th 2017, 4:22 pm
Sweet thanks guys I will go with gear oil does anyone have a particular brand they favor? I am definitely doc locking it asap lol he makes it look so easy. I got some temporary belt retainers on so I can test drive it after I get a bolt for my drive pulley. I will go to the scrap yard tomorrow to find some metal for a bumper and maybe a better brake lever for the gas pedal I've got a couple laying around but they're a bit wobbly lol
huskee trail/utility tractor build  Kimg0930
huskee trail/utility tractor build  Kimg0931
DiezelFuel
DiezelFuel
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 7th 2017, 8:47 pm
Took it for a quick spin but I'm parking it until I fab up a double clutch the belt stays on but its very sloppy and wobbly with the clutch and spring it has.
This is what I'm working with I should have enough belt haha
huskee trail/utility tractor build  Kimg0932
DiezelFuel
DiezelFuel
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 9th 2017, 9:44 pm
I didn't find what I want for my bumper at the yard so I got started on my double clutch I had a piece of 1/4inch slotted plate steel laying around that I think should work perfectly and allow plenty of adjustment.
huskee trail/utility tractor build  Kimg0936
Here is a couple pictures of that plate cut so you can get an idea of what I'm doing.
huskee trail/utility tractor build  Kimg0935
huskee trail/utility tractor build  Kimg0934
huskee trail/utility tractor build  Kimg0933
It will have another piece opposite of the slot welded on so I can bolt it to the frame and attach the spring. It will sort of resemble a T, I will post more pictures tomorrow of the finished product. Very Happy
DiezelFuel
DiezelFuel
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 14th 2017, 1:39 pm
I started a new job so I haven't had much time to work on this. huskee trail/utility tractor build  2429134702 haha I finally got my clutch all welded up though and it is very strong I went with a thicker plate so it has more surface area on the bolt it pivots on. I'm hoping it will keep it more rigid and not wobble like the old one. Laughing
huskee trail/utility tractor build  Kimg0937
huskee trail/utility tractor build  Kimg0941
huskee trail/utility tractor build  Kimg0938
huskee trail/utility tractor build  Kimg0939
huskee trail/utility tractor build  Kimg0940
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 14th 2017, 1:51 pm
Clutch looks real good. I had the same problem with the first double pulley clutch on the MTD, too flimsy and wobbly. The new 3/16" flatstock one is much better haha. I really like the adjustable pulleys idea!
PostSubject: Re: huskee trail/utility tractor build    huskee trail/utility tractor build  Icon_minitimeAugust 14th 2017, 2:16 pm
As long as they do not slide on ya, looks to make belt changes a little easier! Smile
huskee trail/utility tractor build  Sig115PROJECTS:
huskee trail/utility tractor build  Sig214huskee trail/utility tractor build  Sig314
» Craftsman GT-18 Utility/Trail Tractor.
» ROPER Utility\Trail Build
» Utility tractor build
» Huskee Offroad Mower Build
» Poulan utility tractor build.
