| race mower | |
+9Stretch44875 redlinemotorsportts Ariens YT11 Doc Sprocket dylansrockinrigs richie thomas LAWN MOWER MUDDER willis923 jsisti845 13 posters |
k2500life Veteran Member
| Subject: Re: race mower November 8th 2013, 3:18 pm | |
| That thing is pretty awesome | |
jsisti845 Member
| Subject: Re: race mower November 26th 2013, 8:34 pm | |
| Looks sweet. Im diggin the small engine upgrades. | |
jsisti845 Member
| Subject: Re: race mower November 26th 2013, 8:41 pm | |
| I have big plans for this motor wen this is done im looking into billet rod billet flywheel high comp heads cam valve springs stuff like that | |
1997 Murray Veteran Member
| Subject: race mower November 26th 2013, 8:51 pm | |
| Man, that is cool! no one will suspect anything
Last edited by 1997 Murray on November 27th 2013, 7:54 pm; edited 1 time in total | |
jsisti845 Member
| Subject: Re: race mower November 27th 2013, 6:38 pm | |
| - jsisti845 wrote:
- I have big plans for this motor wen this is done im looking into billet rod billet flywheel high comp heads cam valve springs stuff like that
I meant to say high comp head because its only one cylinder lol.... | |
jsisti845 Member
| Subject: Re: race mower January 15th 2014, 12:10 am | |
| sorry for the lack of updates ben too cold and busy with other things I recently stripped it down to the frame again...ugh I hate doing that but I had to weld in some axle bearing supports and I have started re assembly today. I will be doing more work now because I finally got a new welder for xmas and a miter saw. so now I should be wrapping up this build in the next couple of weeks. all that I have left to do is make a gas tank mount, get a sprocket, bakes, and reinforce the body and some other little things. I finnaly ordered some tires off of bmi karts yesterday so those should be in soon. I will post pictures soon im getting excited this build is getting close to being done | |
jsisti845 Member
jsisti845 Member
| Subject: Re: race mower April 7th 2014, 10:01 pm | |
| well guys I lied its ben awile since I did any updates cuz I have no money left lol ive done some work I wired in my kill switch got my tires mounted on my rims bolted my axle in solid so no more pivot. i also had to re do my axle bearings because the rear axle was lower than the front and it looked stupid. i recently pulled the motor out again i still have a bunch of little things left to do like hook up a fuel pump and lines,reinforce the body, weld threads to spindles and order parts. i have no motivation anymore it sucks. but hopefully i will get some money and order some parts. | |
jsisti845 Member
jsisti845 Member
jsisti845 Member
jsisti845 Member
| Subject: Re: race mower April 19th 2014, 9:27 pm | |
| can someone help me out here im having problems with these pics | |
MurryMaddnes Member
Age : 38 Join date : 2014-03-24 Points : 3935 Posts : 32 Location : Green Bay Wisconsin
MurryMaddnes Member
MurryMaddnes Member
MurryMaddnes Member
MurryMaddnes Member
| Subject: Re: race mower April 19th 2014, 9:34 pm | |
| Hope that was all of them didn't do second set they looked to be the same as the first. | |
jsisti845 Member
MurryMaddnes Member
jsisti845 Member
| Subject: Re: race mower April 19th 2014, 9:59 pm | |
| quick update: I just ordered a fuel pump, new bearings for front tires, brake rotor, and lock colors. the one picture is to show off my weld alittle bit im getting better. the other pic shows were the studs come through from my gas tank to mount it. this week I hope to hammer down and get some work done. I still have to finish welding my spindles, installing brake mount and pedal, I also have to make a chain tensonor and figure out how im going to plumb my fuel pump and lines. | |
jsisti845 Member
| Subject: Re: race mower April 19th 2014, 10:03 pm | |
| " /> this is the side gas tank mount | |
jsisti845 Member
| Subject: Re: race mower April 19th 2014, 10:05 pm | |
| " /> heres the top view of the gas tank | |
jsisti845 Member
| Subject: Re: race mower April 26th 2014, 11:02 pm | |
| well guys after two 8 hour days shes finally done I took it for a test drive and she is fast im taking it to my friends house to ride tomaro I will have pics and an update probably monday | |
Age : 37 Join date : 2013-07-02 Points : 5019 Posts : 731 Location : Logan Ohio
| Subject: Re: race mower August 2nd 2014, 10:11 am | |
| Dono how I missed this thing! I love it! and I need an update!!
jsisti845 Member
| Subject: Re: race mower August 11th 2014, 11:16 pm | |
| I know il get around to an update the brakes broke and this has ben sitting ive had no motivation to work on it | |
| race mower | |
