| | Planning, Plotting, And Scheming- Name TBA | |
+19camomanusa kawasaki220 Lawren Wimberly tractor_guy murrayracer GenevaCustoms mudmonkey06 richie thomas Creepycrawler matt-man TroyBilt Pony MowBandit TheBeal Thunderdivine crazykid1994 redlinemotorsportts Stretch44875 k2500life Doc Sprocket 23 posters | |
Doc Sprocket Site VIP
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 9th 2014, 1:11 pm | |
| OH HELLS YES!!! It lives and breathes! I pulled the glow plugs and tested them with my battery booster pack. Good to go, so I screwed them back in. I rigged up a gravity feed test tank to it, and a return line back off the second injector. I connected my battery booster pack to the glow plugs for 30 seconds and then hit the starter... VROOOM
Oh, life is SO good! | |
| | | camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4545 Posts : 467 Location : Greensburg, PA
Age : 51 Join date : 2013-04-21 Points : 7284 Posts : 2914 Location : Ontario Canada
| | | | Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4917 Posts : 919 Location : Defiance, Ohio
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 9th 2014, 2:19 pm | |
| - Doc Sprocket wrote:
- Well, you know what they say... EVERYTHING is for sale at the high price! Hell- I got a couple of kids in good, used condition. LMAO
lol yeah but you need to go with it now I wanna see this thing built like a deuce wrecker! Hell I could help design it if yah want lol | |
| | | | Lawren Wimberly Established Member
Age : 57 Join date : 2013-12-21 Points : 4771 Posts : 744 Location : Salem Illinois
| | | | Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5667 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 10th 2014, 11:55 am | |
lol yeah but you need to go with it now I wanna see this thing built like a deuce wrecker! Hell I could help design it if yah want lol He's got a ways to go, here's mine... | |
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 10th 2014, 12:00 pm | |
*awesome pic* we could figure out a boom of some sort Im sure I think itd be epic! | |
| | | dked41 Member
Age : 60 Join date : 2012-01-31 Points : 4774 Posts : 141 Location : central Wisconsin
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 10th 2014, 12:16 pm | |
- Tec 10hp vertical. The case is actually broken. Owner said something about previous owner using COOKING OIL as a lubricant... Like... WTF?
You could say that sucker DID cook!!! When I was working on a cranberry marsh we used vegetable oil as a lube because a leak would be food safe. I also have heard it being used on golf courses because it was less damaging to turf. | |
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 10th 2014, 1:08 pm | |
| We used mineral oil for lube in Kroger's food plant. Lard was used in place of bearing grease. both food safe, but needed changed more often than dino oils. | |
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 10th 2014, 1:18 pm | |
| I have seen logging companies use veggie oil in places where there are waterway laws (doesnt stop them from sending a few hundred tons of silt down river)
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 13th 2014, 8:57 am | |
| I'll see if I can't toss a pic or two up later this evening, but I did some parts gathering yesterday. Came up with a 62 Amp Delco 10si alternator, a couple motorcycle radiators and cooling fans. Gotta fab up a bracket for the alternator, and figure out a cooling arrangement for it. I'm looking forward to starting it and actually running it for more than 3 seconds. I may have to shoot a video clip when I do. | |
Join date : 2012-12-21 Points : 6509 Posts : 2101 Location : Norway, Europe
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 13th 2014, 10:04 am | |
| - Thunderdivine wrote:
- I have the excact engine Doc, if it's a Kubota Z401.
Right you are! Would you do me a favour then? When you have a chance, measure the radiator surface area for me- not the tanks, just the cooling area. I want to see if what I have available comes close to the stock configuration. Thanks, TD! | |
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 13th 2014, 10:43 am | |
Right you are! Would you do me a favour then? When you have a chance, measure the radiator surface area for me- not the tanks, just the cooling area. I want to see if what I have available comes close to the stock configuration. Thanks, TD! Sorry the Z402 is the one i have, and guess what mine's connected too? (in the term of a clutch) And i can do that. | |
| Subject: Re: Planning, Plotting, And Scheming- Name TBA February 13th 2014, 12:08 pm | |
- Thank you. I believe this is a z400, but I'm not quite certain. That's what I was told. Is yours currently powering something?
Yeah its powering my back and forth work transportation lol | |
| | | | Sponsored content
| Who is online? | In total there are 45 users online :: 0 Registered, 0 Hidden and 45 Guests
