 Tecumseh HH100 Stroke Crankshaft
jd112
6 posters
jd112
Tecumseh HH100 Stroke Crankshaft  Empty
PostSubject: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 21st 2013, 8:02 pm
Hey Ya'll
I'm new here and I am in need of some help. I am wanting to build my HH100 up to put out some serious horsepower and torque (within reason) Here is what I want to do. Bore .020 over, Stroke, reseal, rering, cam up, and some head work. I can do the head work, I have new sleeves on the way, I can bore it, but I need some help with putting a stroker crank shaft in it. What I want to do is go as strong as I can without causing issues with the block. I am attempting to build the motor for a John Deere 112 demo tractor and I am in need of all the horse power I can get. Thanks fellas
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 21st 2013, 8:42 pm
Welcome what horse power? And got pics
http://www.lastdropgarage.com
jd112
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 21st 2013, 9:06 pm
It's 10 horse, I dont have pics yet, I'll try but School starts tomorrow and I probably wont have much time to work on it during the school year.
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 21st 2013, 9:09 pm
Ok ya I here ya My school started 3 days ago
jd112
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 21st 2013, 9:16 pm
Regular school or tech school? I might be able to talk my teacher into helping me out with the cad part of CNC ing the new part... Now there's an Idea but that would be a huge pain in the capitains quarters... dunno
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 21st 2013, 9:17 pm
Reg school but I have auto
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 22nd 2013, 9:53 am
I don't have any input on the performance mods themselves, but just a quick FYI:
If you crank out serious horsepower, you will need to also beef up everything down the line. You can break almost anything on a stock tractor with a stock motor. Once you start making the engine into a monster, you'll need a monster transaxle too.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
jd112
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 22nd 2013, 6:59 pm
I haven't broken into the transaxle yet but being its a 60's axle it should hold up shouldnt it? It looks so far to be pretty heavy duty. If not what mods will need to be done?
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 23rd 2013, 10:43 am
Not sure what can be done to a stock axle... my point was that we broke transaxle cases, broke axles, cracked frames, broke rims, etc. all with the horsepower generated from stock engines minus governor.  If stuff is breaking under stock horsepower, increasing the horsepower like you are describing will increase the stress on everything downstream and break more stuff, more often.
A good example is Stretch and I ran our tractors for years with 600 series peerless transaxles.  We broke cases and snapped axles as I said, but they lasted ok for the most part.  Once we graduated from running 10 - 14HP singles to running the current engines we use, 16 - 20HP twins, the transaxles pretty much started falling apart, and we had to upgrade to the 820 series peerless transaxles we are using now.
Now... that said... I'm not saying DON'T mod your engine to squeeze every last drop of power out of it you can.  I'm just saying, understand that the more power you have, the better built everything else has to be.
Chaos Build
Haspin 2021 thread
jd112
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 23rd 2013, 4:08 pm
I completely understand that believe me. Where can one find a couple of peerless 820's? I might want to build a 4x4 with them. The nice thing about the mower I'm building right not is it wont see much off road use, as I am demoing it and everything is liable to break any way.
Moderator edit, transaxles used are actually 820
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 23rd 2013, 4:15 pm
Got any pics?
jd112
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 23rd 2013, 4:27 pm
I'll get some up later tonight after I get in from working on it and going to a church event.
jd112
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 23rd 2013, 10:09 pm
Where can one find peerless axles that are some what affordable?
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 23rd 2013, 10:37 pm
We get ours out of "side of the road" tractors, or Stretch has a tractor junkyard he knows of. They typically aren't free. My guess is you'll pay between $50 and $100 for a used one.
Chaos Build
Haspin 2021 thread
Jerbear0612
Jerbear0612
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 24th 2013, 12:41 am
The transaxle you have in the 112 now is a peerless 2300. I had one in my John Deere 212 garden tractor. They're a very durable gear fluid filled transaxle. Also the pulley for the transaxle is mounted horizontally, you'll have a somewhat hard time swapping in an 820 which has a vertically mounted pulley and making it work
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 24th 2013, 7:53 am
I would also suggest stick with what you have, it's a tough tranny.
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 27th 2013, 10:46 am
Getting back to the engine thing, do keep in mind that Tecumseh has now been defunct for a few years and parts are getting tougher to come by, especially performance goodies. If you can machine stuff, that's great. But you may actually be better off to start with something more common with better OEM and aftermarket support.
jd112
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 27th 2013, 5:14 pm
Would the kohler version be any easier to mod?
Jerbear0612
Jerbear0612
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 28th 2013, 7:28 am
Yes The kohler k series (10-16hp) have more after market support and performance mods as they are used alot in the garden tractor puller world
PostSubject: Re: Tecumseh HH100 Stroke Crankshaft    Tecumseh HH100 Stroke Crankshaft  Icon_minitimeAugust 28th 2013, 7:43 am
The Kohler's are more popular, sure- but expensive from what I can gather. Maybe look into something a touch more common? You've got a horizontal shaft engine, right? May I suggest a Honda GX340 or one of the more popular clone brands like the Predator 420? Aftermarket support is good, and parts are relatively cheap and easy to come by.
» Tecumseh hh100 carb
» Tecumseh hh100 carb?
» Why does a 2-stroke gas need to have a gas-oil mixture and a 2-stroke deisel doesnt?
» Rig for testing crankshaft endplay.
» My crankshaft seal leaks on my 12.5hp briggs vanguard.
