 Chain driven mower
EROCK
6 posters
EROCK
Chain driven mower Empty
PostSubject: Chain driven mower   Chain driven mower Icon_minitimeAugust 1st 2013, 10:58 am
Does anyone have an idea for a clutch if I were to basically remove the belt and pulleys and use sprokets and chain on a mud mower?
PostSubject: Re: Chain driven mower   Chain driven mower Icon_minitimeAugust 1st 2013, 11:36 am
Using a centrifugal clutch would allow you to do that. There are a couple guys on here doing those kind of builds.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
EROCK
PostSubject: Re: Chain driven mower   Chain driven mower Icon_minitimeAugust 1st 2013, 2:48 pm
I know I could do that but is there a way without buying a clutch? And besides, would that work when its hanging upside down?
Speedfreek241
Speedfreek241
PostSubject: Re: Chain driven mower   Chain driven mower Icon_minitimeAugust 1st 2013, 2:51 pm
you have to have a clutch or some way for it to slip.
PostSubject: Re: Chain driven mower   Chain driven mower Icon_minitimeAugust 1st 2013, 2:57 pm
Without a clutch, you won't have any slip or way to disengage under load except to shut the mower down. Not exactly a good mix when running chain all around.
Marines2621
Marines2621
PostSubject: Re: Chain driven mower   Chain driven mower Icon_minitimeAugust 1st 2013, 6:58 pm
Lol listen to these other guys. Without slip u will not be able to shift even if you could, id say bye bye to your trans and the gears in it.
crazykid1994
crazykid1994
PostSubject: Re: Chain driven mower   Chain driven mower Icon_minitimeAugust 3rd 2013, 9:04 am
centrifugal clutch or a cvt are your only 2 options
crazykid1994
crazykid1994
PostSubject: Re: Chain driven mower   Chain driven mower Icon_minitimeAugust 3rd 2013, 9:06 am
or run an atuomatic/hydro like i did when i ran chain. it popped wheelies and spun tires. still works no problem. just snapped the chain
PostSubject: Re: Chain driven mower   Chain driven mower Icon_minitimeAugust 3rd 2013, 9:24 am
You will need a clutch. Without any clutch, you will-
*Not be able to start the engine without beginning to roll immediately
*Not be able to come to a full stop without shutting down or stalling the engine
*Not be able to shift gears without breakage.
You would-
*Have to put it in neutral to start and warm up the engine on a cold start
*Then, after engine is warm, shut it off, put it in 1st or 2nd, and restart engine to begin moving
*To come to a complete stop you would have to shut engine off or brake hard until engine stalls
*To reverse, shut engine off, restart in reverse, shut off again, restart in forward,
etc etc etc.
Trust me, you need a clutch of some kind. Otherwise, it will be a total pain in the ass to drive.
Chain driven mower
» First Build
» HD MTD (Honda Driven)
» Belts vs Chain
» Belt or chain
» need help with chain length
