 What engine can I use to RE-Power my offroader?
CraftsMAN
CraftsMAN
What engine can I use to RE-Power my offroader? Empty
PostSubject: What engine can I use to RE-Power my offroader?   What engine can I use to RE-Power my offroader? Icon_minitimeJuly 20th 2013, 3:42 am
I like the 19.5hp briggs twin engines and was wondering if one would mount up to the tractor in my video?
https://www.facebook.com/CRUSHEMCustoms/
PostSubject: Re: What engine can I use to RE-Power my offroader?   What engine can I use to RE-Power my offroader? Icon_minitimeJuly 20th 2013, 5:28 am
Assuming those holes are the standard spacing (cant remember off the top of my head) then yes it will fit.
PostSubject: Re: What engine can I use to RE-Power my offroader?   What engine can I use to RE-Power my offroader? Icon_minitimeJuly 20th 2013, 7:53 am
If the holes do not line up, you should still be able to pull it off with careful measurements. If you can get the engine positioned so that the shaft ends up in the original location, you would just have to drill new mounting holes. If not, you may have to mess with belt sizes.
PostSubject: Re: What engine can I use to RE-Power my offroader?   What engine can I use to RE-Power my offroader? Icon_minitimeSeptember 3rd 2013, 7:28 pm
you can put anything you want on it.. its just a matter of measuring and fabricating. make sure the output pully is centered as the old one was, and you'll be set. if it dont line up, fab up some motor mounts. having to center everything will be a PITA, but can be done
» bbuckler's Rear Engine Offroader [2017 Build-Off Entry]
» Honda HT-R 3009 mid engine rider engine swap
» mtd offroader
» Craftsman Offroader
