| The Mudding Craftsman | |
+19camomanusa TroyBilt Pony Creepycrawler ModdedMudder k2500life motorizedeverything Craftsman Dude greener179 crazykid1994 Stretch44875 Thunderdivine MurrayMayhem Doc Sprocket richie thomas truckin42 MowBandit TheRainbowBoxer redlinemotorsportts craftsmancole 23 posters |
Age : 25 Join date : 2013-04-05 Points : 4956 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: The Mudding Craftsman July 16th 2013, 11:54 am | |
| After that video I found out that the choke wasnt hooked up right, doesnt need carb cleaner to start now. | |
MurrayMayhem Member
Age : 25 Join date : 2013-01-03 Points : 4452 Posts : 99 Location : 820 Opposed Twin RD. AxleBreaker City
| Subject: Re: The Mudding Craftsman July 16th 2013, 1:18 pm | |
| Yep, you're just as close to finishing as me, in theory, mine will be running and driving in 1 week.
MurrayMayhem Member
| Subject: Re: The Mudding Craftsman July 18th 2013, 5:04 pm | |
| New update on mine CC, it started. I jump started it off my neighbors truck, not as loud as your mower but still respectable. Still have to get new sparkplugs, but now I know it works, so I can spend money on it. | |
| Subject: Re: The Mudding Craftsman July 22nd 2013, 3:23 pm | |
| Ok MM, got my bumpers on today and getting a belt Wednesday, got my hood on and clutch on, the motor sounds better with the hood on, my tires go low extremely fast and I found a $100 bill I didn't know I had so I'm getting tires!
Age : 27 Join date : 2013-03-18 Points : 7477 Posts : 3131 Location : raleigh nc
| Subject: Re: The Mudding Craftsman July 22nd 2013, 6:57 pm | |
| is it possible if you and mm get both of your rigs ready will you get a video of them mud bogging? | |
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5365 Posts : 1135 Location : Southern Florida
MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4743 Posts : 477 Location : Haddock,Georgia
| Subject: Re: The Mudding Craftsman July 30th 2013, 2:22 am | |
| I still have to play with my clutch to get it to work, its a mater of playing with idlers. Getting a 18hp oppy, hopefully this weekend so i can romp around with MurrayMayhem, his is running and drives needs more tension tho nuthing random idlers wont fix! | |
| Subject: Re: The Mudding Craftsman August 28th 2013, 4:36 pm | |
| Sorry for my absence, I've been really busy I have a AP course and its a lot of work im selling this without the 820, thats mine, with 19" wan da's a Spicer 15" Duro turns in the front and the 15 I/C Gold oppy all working awesome bumpers for $185 | |
| Subject: Re: The Mudding Craftsman October 26th 2013, 10:36 pm | |
| Well guys ignore my last post, I was being stupid, I have decided that I'm rebuilding this thing to be a monster! I'm planing on lifting (of course), getting a right angle gear box from my friend, a starter for my 23hp Kohler, a 1" axle and 1" bore pillow block bearings, and probably some 27" Kenda Executioners | |
| Subject: Re: The Mudding Craftsman October 27th 2013, 10:10 am | |
Last edited by craftsmancole on November 19th 2013, 11:17 am; edited 1 time in total | |
ModdedMudder New Member
Join date : 2013-07-13 Points : 4151 Posts : 6 Location : Florida
| Subject: Re: The Mudding Craftsman November 19th 2013, 11:31 am | |
| I did a lot of work on this during the 3 hours i got to work on it this weekend, it has the 20 hp single cyl Kohler, 820, 19" Wan Da's on the front and 27x12x12 Firestone ag tires in the back. All i need to do now is weld up the exhaut, weld spindles, put on the pulleys and belt then she'll romp! | |
MurrayMayhem Member
| Subject: Re: The Mudding Craftsman November 19th 2013, 1:53 pm | |
| Speaking of huge mowers, my lil murray will no longer be little, it will be a big mower just like the lifted used to be, the lifted will be 3 times the size of what it used to be! | |
| Subject: Re: The Mudding Craftsman November 19th 2013, 5:10 pm | |
| Im getting a lot done on the craftsman and im like "yay ill be able to drive it this weekend!" And the kohlers like nope. The pulley is completely rust-bonded to the shaft i tried taking it off with the pullers and the air wrench and that p.o.s. bent all up and didnt budge!! Im freaking pissed | |
Age : 37 Join date : 2013-07-02 Points : 5013 Posts : 731 Location : Logan Ohio
| Subject: Re: The Mudding Craftsman November 20th 2013, 9:03 pm | |
| I like it man, looks good so far. def. like the rear bumper, your gonna get covered though with the tires sticking out so far
| Subject: Re: The Mudding Craftsman November 23rd 2013, 8:04 am | |
| I know ill be covered, it wouldve happened even if i had the 24s cause im pribably gunna bury this so bad that my jeep will have to pull me out! I abuse stuff so i know whats weak and has to be fixed (on my first couple romps, then ipl go a bit easier on her) | |
