 The Mudding Craftsman
camomanusa
TroyBilt Pony
ModdedMudder
motorizedeverything
Craftsman Dude
greener179
crazykid1994
MurrayMayhem
MowBandit
23 posters
crazykid1994
The Mudding Craftsman - Page 3 Empty
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 29th 2013, 6:37 pm
thats going to b a lot of stress on the tranny tho. pushing 4 tires
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 29th 2013, 6:40 pm
itll hold, 820 24x9 in the back, 23x7 in the front.
greener179
greener179
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 29th 2013, 7:20 pm
All lifting it is going to do is make it less stable
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 29th 2013, 7:32 pm
I need to get through lots of water
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 29th 2013, 7:39 pm
I would try to get the rear axle / wheels behind the seat at least.
And maybe a center shaft instead of the chain.
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 29th 2013, 8:54 pm
I'm going 2WD cause I'm lazy...
And I'm lifting only one foot.
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 29th 2013, 11:25 pm
trust me, do a smaller lift, mine is only lifted 10" and its to much to be of any real use to be honest
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 12:44 am
Ok Richie, so I should do like 5-6" lift?
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 1:10 am
if i could redo mine, id do a 6, or at the very most a 8, mine is a 10" and its way to much lol, also, when you lift it move you front axle as far front as you can, and it wouldn't hurt to slide the rear axle back 1 or 2", the 27" tires will clear with a 6" lift, if you slide the tranny back 2 inches, but remember that the best thing to do when doing the lift, is going to be to have the size of the tires known, and then build the lift based of that, whe i built mine, i built it for a 5" difference in tires, and now that i only have a 2" difference, i have to redo my front lift,if you get the tire size you want figured out for the front and the back post them and ill help you with the size lift you will need, because it will be different on the front and the back, and you have to accommodate that,for example, on mine, it has a 10 on the back, and will have a 6 on the front when i redo the front, that is the length of the actual lift i built for it, but then the tires on the front add into it and give it the rest and same on the back, my frame is sitting right at 10 inches higher than stock, and its to high lol
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 1:13 am
K im actually gunna put Interco Vamps on it, 27" when I get the money so it'll take a while...
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 1:57 pm
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 2:18 pm
call me odd, or old school or whatever else you choose but the mockup you have here is what I'd do right off... still, it sounds like you have it figured out pretty well Smile good luck in your build!
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 2:24 pm
Thx EDI, I might move the axle further back so 26" or 25" tire will fit
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 2:45 pm
26" Vamps (http://traxms.com/ATV-Tires-Mud_ALL_Interco_Vampire.html), 25" Outlaw MSTS (http://traxms.com/ATV-Tires-Mud_ALL_OutlawMST.html), or 25" ITP Mayhems (http://traxms.com/ATV-Tires-Mud_ALL_ITP_Mayhem.html)?
So back to this, which tire?
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 4:29 pm
or Duro Mud and Sand Tire or Kenda Exicutioners? Cheaper than the rest!
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 4:57 pm
or Duro Mud and Sand Tire? Cheaper than the rest!
Link?
and id say why not some bearclaws? they come in many sizes and are cheap.
Also do you know? that you can edit a post and add in links later, to keep it more tidy.
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 5:00 pm
Not that much of a fan of those... I like really aggressive looking tires!
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 5:40 pm
How is this not aggressive Smile Remember, you want a tire that you can use aswell, your not only gonna look at it.
Craftsman Dude
Craftsman Dude
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 10:48 pm
I would lift it just enough to clear the tires you want to run, move the front end as far forward as possible and move the rear back at least 2 inches just for safety and stability. You may want to look around more for tires there are ALOT of options ive got some ams swamp foxes and I love them they have over 1 inch tread if you go with a 26 inch or bigger, ive got 25s and there great but let me warn you they hook lol I ripped the hub of my axle doin wheelies lol.
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJune 30th 2013, 11:01 pm
All right, I'm looking to get Duro Mud and Sand ATV Tire, 25x10x12s
$77 a tire.
MurrayMayhem
MurrayMayhem
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJuly 1st 2013, 7:45 pm
Bear claws do not have good traction, if you want traction in all terrains get some Duro Mud & Sand Tires, I ran 22x12x8's on my little murray and those duro's held up full of water, doing wheelies at full throttle and climbing hills and mudding.
crazykid1994
crazykid1994
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJuly 1st 2013, 7:59 pm
just random but theres also carlisle super lugs?
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJuly 1st 2013, 8:57 pm
im gunna get 25x10x12 Mud and Sands
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJuly 1st 2013, 9:01 pm
How is this not aggressive :)Remember, you want a tire that you can use aswell, your not only gonna look at it.
I still dont like.
motorizedeverything
motorizedeverything
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJuly 1st 2013, 9:05 pm
like these
The Mudding Craftsman - Page 3 Img_0310
PostSubject: Re: The Mudding Craftsman   The Mudding Craftsman - Page 3 Icon_minitimeJuly 1st 2013, 10:17 pm
Yes,.they look like off brand Mud Machines
Page 3 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» Extreme Craftsman mudding project!!!!
» Craftsman Mudding Lawn Tractor
» Craftsman Lawn Mower Mudding
» OFFROAD Craftsman LT4000-2 mudding mower (MTD12HPTURBO)
» Craftsman GT 18 Mudding Tractor Head Lights and Basket
