| What do I need to do to swap a fuel pump to a gravity fed one? | |
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5800 Posts : 511 Location : Southern WV
| Subject: What do I need to do to swap a fuel pump to a gravity fed one? July 7th 2010, 9:46 am | |
| I'm thinking of swapping my pump fed opposed twin into a gravity fed mower. Since the same motor came in gravity fed configuration I'm sure it's possible but I'm very new to small engines. So what exactly would I need to do? Pull off the pump obviously. | |
Guest Guest
Chunk Established Member
Age : 33 Join date : 2010-02-10 Points : 6214 Posts : 779 Location : Angus, Scotland
| Subject: Re: What do I need to do to swap a fuel pump to a gravity fed one? July 7th 2010, 1:53 pm | |
| Well, I read where someone had a pump, but they ran a tank higher than the carb, and it had flooding problems. So it's either move the fuel tank somewhere else, or switch to gravity feed. I'm not opposed to the pump, especially since I rebuilt it last week. I just want it to work properly though. | |
Age : 54 Join date : 2010-02-10 Points : 7070 Posts : 1726 Location : Florida, USA
| Subject: Re: What do I need to do to swap a fuel pump to a gravity fed one? July 7th 2010, 2:26 pm | |
| Id stick with the pump too - those twins are hungry for fuel - i dont think a gravity fed tank would work that well. Most my twin cylender pumps have never been rebuilt and still work great. A good way to see how much fuel is flowing to the carb: use a short piece of clear fuel rated tubing - its probably a good idea to replace those old rubber fuel lines anyway - they do detiriorate over time and can clog or contaminate the fuel going into the motor.
The majority of my twins use the carb mounted fuel pump - however my 18HP opposed horizontal has this huge vacuum fed fuel pump on the plate that mounts behind the motor- that tank is running from the back of the tractor and really needs it. | |
Guest Guest
| Subject: Re: What do I need to do to swap a fuel pump to a gravity fed one? July 7th 2010, 6:32 pm | |
| Yeah, Ive always wanted to use a 5 litre gas can for a fuel tank. That was me who had the flooding problems. It was stuck float, which coincidently happened right after I had the fuel tank mounted up above the pump. Shear conincidense though. You should be fine running it like that. | |
| Subject: Re: What do I need to do to swap a fuel pump to a gravity fed one? July 7th 2010, 6:35 pm | |
| Cool, good to hear. I only remember about half of what I read, haha. The gas can is a great idea as well. What type of sealant/adhesive would you guys suggest for the barb fitting at the bottom to attach a fuel line? Needs to seal tight and hold up to fuel. | |
Guest Guest
| Subject: Re: What do I need to do to swap a fuel pump to a gravity fed one? July 7th 2010, 6:39 pm | |
| RTV sealant m ight work, cant rembmer if that holds up against fuel though.
My immedate thought was becuase it was mounted up high, because that was the only thing that had changed for the test run. Through me off. It had no filter on it, and I guess it just had crap in the line. So theres another lesson for you, even if you're just test running something, use a filter! lol. Could save you a head ache. | |
| Subject: Re: What do I need to do to swap a fuel pump to a gravity fed one? July 7th 2010, 6:43 pm | |
| Absolutely, filters are there for a reason. I was helping a neighbor get their push mower running the other day. No filter, left outside in the rain. Turned out to have a blockage in the fuel line too, which under compressed air shot through the garage like a BB. Lack of maintenance amazes me. Stuff costs too much to just let go like that. | |
| Subject: Re: What do I need to do to swap a fuel pump to a gravity fed one? July 7th 2010, 10:34 pm | |
| Dont use RTV - a bolens i got from my wifes step brother ( redneck engineered the crap out of it) - he mustve cut the tank with a grinder- was a narrow cut near the bottom- he plugged it with RTV ( unbeknowst to me) and after i filled it half full with gas- i wondered why the next day it was empty.
Id say use an epoxy or if youre drilling a slightly tight hole ( need to thread it thru the tank) use a gasoline proof rubber gromit on both sides and put it near the opening to put a retaining nut on it.
Yeah its amazing what people do to save money when working on tractors - ive had alot of them - my 84 dynamark- the guy welded the front deck bracket to the deck and welded the one cracked side at a weird angle as well ( crappy weld also) - my 99 weedeater had seized spindles and no deck blades - my 90 task force had hob jobbed wiring but oddly enough i drove it home around the corner- to name a few.......usually i make sure the motor runs, then look at how much itd take to fix it , then decide to fix or parts it - another thing that makes my mind up is if i like how it looks- then it doesnt matter- it comes apart and i go thru the whole thing.
