| What oil do YOU use? | |
+32WilliesBuilds Lawren Wimberly 83ratrodmurray Craftsman1998 T-Dub13 richie thomas the54 dukas crafsmankiller mr.modified BlackMountian88 Ariens YT11 joshualee3d redlinemotorsportts Doc Sprocket crazykid1994 TroyBilt Pony jack9102 willis923 TheRainbowBoxer Marines2621 twinbrothers99 mudmonkey06 cumminsbayou Kel W1ldyOvvnZ Chopperhed tractorboy567 xxXMowerdudeXxx truckin42 Thunderdivine Doug 36 posters | |
Doug Site Owner
| Subject: Re: What oil do YOU use? March 17th 2014, 9:30 pm | |
| Im running Advance Auto 10w-40 now since I buy it by the case for my truck. Seems to work fine. | |
| | | T-Dub13 Established Member
Age : 55 Join date : 2013-12-06 Points : 4566 Posts : 540 Location : Central MA
| Subject: Re: What oil do YOU use? March 18th 2014, 9:45 am | |
| - vinsanity wrote:
- I run only Rotella diesel oil(zinc baby) in my opposed briggs. Either t5 or t6, what ever is on sale. I also change it every 10 hours or so. It's a non pressure lube and I beat the piss out of her so I don't want to risk frying the top rod. Sometimes I will even run a very lean mixture of 2 stroke oil in the gas just to keep the bore happy. That and it just smell good. I know, I'm crazy haha.
I burn my old 2T race fuel in my tractor after it gets too old to trust in my bikes. Smells great! I wouldn't worry much about frying the top end in any of these machines as long as they're not built to run insane compression ratios. | |
| | | Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4945 Posts : 919 Location : Defiance, Ohio
| Subject: Re: What oil do YOU use? March 18th 2014, 2:00 pm | |
| what you can change the oil?!?!? huh lol havent done that in forever! | |
| | | vinsanity New Member
Join date : 2014-03-14 Points : 3920 Posts : 15 Location : Orange county New York
| Subject: Re: What oil do YOU use? March 19th 2014, 10:05 am | |
| - T-Dub13 wrote:
- I burn my old 2T race fuel in my tractor after it gets too old to trust in my bikes. Smells great! I wouldn't worry much about frying the top end in any of these machines as long as they're not built to run insane compression ratios.
Yea a friend of mine does the same. And it's not so much that I think I am going to fry the top end. It just gives me an excuse to romp on it that much harder | |
Join date : 2012-12-21 Points : 6537 Posts : 2101 Location : Norway, Europe
| Subject: Re: What oil do YOU use? March 19th 2014, 1:07 pm | |
| Just a reminder if you have an old engine, and run full synth oil. It will ruin your gaskets and seals. (if you get strange oil leaks) - Old meaning before 80's i think. After that they started using Nitrile seals and gaskets. | |
Age : 57 Join date : 2013-12-21 Points : 4799 Posts : 744 Location : Salem Illinois
| Subject: Re: What oil do YOU use? March 19th 2014, 3:48 pm | |
| Probably the most important thing is to make sure you have SOME kinda oil in it. I've seen an awful lot of motors lost because some dummy just ran the thing till it was dry, then ran it some more.... Till it stopped. In the south here I use cheap dollar store 30 wt... I've never had a problem. Wintertime in Montana I ran atf... temps often dipped into the -60F range, and even atf sometimes needed some heat to loosen up. A hair dryer set blowing on the block for a few minutes would usually thaw the atf enough to turn the motor over. I CAN tell you that at -70 to -92 degrees F you are not gonna move. | |
Age : 29 Join date : 2011-08-04 Points : 6394 Posts : 1434 Location : east dublin georgia
| | | | matt-man Member
Age : 27 Join date : 2013-07-26 Points : 4385 Posts : 221 Location : North Fort Myers, Florida
| | | | craftsmancole Established Member
Age : 25 Join date : 2013-04-05 Points : 4956 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: What oil do YOU use? April 20th 2014, 4:19 pm | |
| I use what I have laying around, which is either 15w-30 or 15w-40 | |
